Old 04-12-2012, 06:04 PM
smileynialley's Avatar
smileynialley smileynialley is offline
smileynialley is on a distinguished road
Default Urgent help needed with wiring problem.
Hi guys,
I was re-wiring my headunit to my headrest monitors today and while doing it a red wire sparked on the metal work and took out my headunit.
This is the red wire:
It is fairly thick and appears to be a power supply cable but was not attched to anything and had a bare end. It was located underneath the centre console/armrest and runs from the dashboard area..
This cable no longer has power to it so im assuming the head unit and the cable are running off the same power feed.
I have tested each fuse under the bonnet and they are all fine.
The head unit appears to have a permenant live still running to it as there is a small red light on the side of it but it will not turn on to normal operating mode.
Can anyone help or shed some light on how i get this cable and head unit working again.
