Old 04-18-2012, 01:32 PM
clearlaketx clearlaketx is offline
clearlaketx is on a distinguished road
Default 2003 H2 Air suspension hose diagram
Can anyone Post a drawing of the compressor/hose/airbag system for an 03 H2?
I am doing some work and it would be very helpful.
Thanks.
Old 04-18-2012, 02:57 PM
mbdougl's Avatar
mbdougl mbdougl is offline
mbdougl is off the scale
Default Re: 2003 H2 Air suspension hose diagram
Does this help? http://www.2405.com/press-library/Hu...ension-air.jpg
Old 04-19-2012, 12:08 AM
Thanks for the photo but its not quite what I need. I was looking for a parts diagram like out of a service manual.
I have ordered springs to make the conversion BUT they will not be here for 7 days. I was wanting to put in a T connection so I can fill the airbags manually from the air fitting in the back cargo area. Anyone done this?
After I do the conversion I would like to put some sort of compressor in place of the OEM unit so that I can use the air fitting again. having an onboard air compressor is darn convenient! Has Anyone tried to rebuild their compressor? Scot
Old 05-07-2012, 01:52 PM
Rene S. Nielsen Rene S. Nielsen is offline
Rene S. Nielsen is off the scale
Hi
I have fitted a T converter under the truck since my compressor broke and I have been running like this for more than 1 year, works without problems.
Just pull the compressor out there will be 3 hoses left connect them all together and you are done.
After pulling the compressor it's a 5 min job. But the tricky part can be to loosien the hoses from the compressor, there is a thread about it somewhere here.
regards
Rene
