05-12-2012, 09:44 PM
Moderator
AC repair questions
Ok, well the AC is out on the truck.
I went and had it charged, and within a half and hour if that (without the truck even running) it was completely gone.
I talked to one guy, and site unseen, he said it was the compressor. He stated that the GM compressors were known to leak and leak bad (weird, my 99 Vette hasnt had one problem).
Ok, so I am pretty handy with a tool and was wondering how hard it is to do an AC fix. I was wondering if there was any step by step guides or something to help me diagnose the issue and fix it.
If it is the compressor I am wondering, if reman'd units are any good and if so where is the best place to buy them? I have seen them for 150-300 bucks, where a new one is 500-700.
Thanks in advance
05-12-2012, 09:58 PM
Re: AC repair questions
I did the entire system on my 06 GTO a while back. Actually not too difficult.
As for compressors I would recommend an actual AC Delco compressor and not going the cheaper route. Its a project I think most people can handle but not something you'd want to do a second time because a reman compressor is having issues.
IF it is the compressor that would need to be replaced, typically you would also replace the dryer and evap core as well as having the condensor flushed-you don't want the new compressor sucking junk into it. You then have to add a specific amount of oil to the dryer/compressor then charge the entire system, check for leaks, temp test, etc.
I did it without ever messing with a car AC system and everything turned out great. My only setback was using an AC O-ring kit from auto zone which were cheap and one was leaking. Replaced with a higher quality o-ring and everything was great.
05-12-2012, 11:11 PM
First things first, inspect condenser for signs of damage, may have a hole in it from road debris. Inspect all components for signs of leaks, newer units come pre installed with leak detection dye which will show up with a black light. After that and still unable to locate leak take it to an ac shop and have them put a partial charge in system and check for leaks with a leak detector. Spending a little time and money on diagnosis and not somebodys word on it could save you lots of money on a compressor you didnt need
1998 Chev Z71
2007 Chev Trailblazer SS
05-13-2012, 01:00 AM
Moderator
Thanks guys
Is there any guides or how to that would guide me through this?
I tend to be able to do alot when it comes to automotive, but if i have never tackled it before i am more of a show me once and i know it forever type.
(and ummm as you can probably tell I havent ever worked on an AC before)
Like I know the components, but it would be nice to see where they were at on the truck, or where I can place the dye.... and so on.
Any help is appreciated.
05-13-2012, 03:11 AM
You did try the $13 can with the charge and sealant in it first right?
05-14-2012, 01:36 AM
also FYI those cans with the gauge on them aren't worth the crap-there's no replacement for a high quality set of gauges
Hybrid Mode
