Old 05-27-2012, 03:44 AM
dare8601 dare8601 is offline
dare8601 is on a distinguished road
Default blowing hot and cold
Had new climate control replaced (new from GM) air cond. cold air coming out all vents..but today hot on drivers side vents and cold on passenger side...I thought replacing the control was the fix...any help ...H2,2003..
Old 05-27-2012, 01:50 PM
Bstates Bstates is offline
Bstates is on a distinguished road
Default Re: blowing hot and cold
I had the same problem on my 05 h2 last summer. The actuator that controls the driverside temperature is located under the passenger side glovebox. To replace all you need to do is remove the cover then you will have access to the blower motor and then next to the center console you will see the actuator, the part # Dorman 604106 it has 3 screws holding in and one connector. I bought mine at autozone. There are 2 different actuators for the h2 and unfortunately it's the higher priced one. Hope this helps. I'm sure that doing this saved me over $300 from going to the dealership. Good luck!
Old 05-27-2012, 11:43 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
When you changed the control module did you have it programmed and then did an actuator recalibration? If not try that.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 05-28-2012, 04:17 AM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
I know you have to initially calibrate the actuator but you also have to program the climate control module?
Old 05-29-2012, 12:12 AM
HUMTECH's Avatar
Just double checked, an 03 requires no programming
1998 Chev Z71
Old 05-29-2012, 12:20 AM
I don't know if it was cal. I will call the place who installed and see....thanks a Mil.
Old 05-29-2012, 01:12 AM
I checked the location for the part that needs changed...looks simple..thanks again..
Old 05-30-2012, 02:25 AM
part #604-106 $132. Worth every penny when cold air works on the drivers side now...
Old 05-31-2012, 02:19 AM
well that didn't work....back to hot and cold
Old 05-31-2012, 03:50 AM
HUMTECH's Avatar
Get it scanned for codes and then i might be able to help
1998 Chev Z71
Old 06-01-2012, 02:01 AM
I disconnected the Neg. battery and let set for a few min. went for a ride and it seams to working now...will check again Friday.....HUMTECH, if it does it again will have scanned..thanks
