Old 06-26-2012, 03:07 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
Default Clearance Lights (Cab Front)
Any trick to replacing bulbs in front cab lights ( three in center ). Does the whole light have to come out or does the Lens come off ??
Thanks in Advance Guys...
2004 Hummer H2 " Metallic Red "
20 inch Mojave's (Teflon)(325/60/20) BFG A/T's
MagnaFlow kitty back...Hypertech Tuned..Music to my ears
HCMI Member 50043
Old 06-26-2012, 03:18 AM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Default Re: Clearance Lights (Cab Front)
You take the whole assembly out then remove the bulb.
Old 06-26-2012, 03:24 AM
Is there any screws ? Or does it just pop in ? Give a twist ?
HCMI Member 50043
Old 06-26-2012, 10:34 AM
LoJac963's Avatar
LoJac963 LoJac963 is offline
I believe the center ones twist in. They do have a seal on the bottom of them that I would imagine would get pretty stuck to the metal after time so it might have to pursuade it
Old 06-28-2012, 02:59 AM
They clip in. Take a small flat head screwdriver and push in. One side lifts up first then the other.
