Old 06-27-2012, 12:50 PM
markkiemark markkiemark is offline
markkiemark is on a distinguished road
Default Newbie wheel question
My H2 came with 20" wheels and 325/60/20 tires and I get a slight rub at full lock. Any way to compensate for this? I don't have the specs on the wheels so I hope this info helps. Thanks!!!
Old 06-27-2012, 02:00 PM
guruerror's Avatar
Default Re: Newbie wheel question
If it truly is only a 'slight rub' I would assume that cranking your torsion bars (and/or installing GM green keys) would fix it on the cheap. It'll lift the front a bit and make the truck set more level from front to back. In my experience, this also effected the smoothness of the truck's ride, especially when going over bumps...made it more harsh.
IMO, the best way would be to get a Cognito Upper Control Arm (UCA) kit. It will lift the front, level the truck, reduce that stress on your steering components, and maintain the factory feel to the ride...but this is obviously more expensive than the above.
CNTRY
DTOM
Old 06-27-2012, 09:44 PM
mbdougl's Avatar
mbdougl mbdougl is offline
mbdougl is off the scale
Or you could buy a more reasonable size wheel and tire combination 18x9 Rockstars - LT325/65R-18 Goodyear Wrangler DuraTrac
Old 06-28-2012, 01:25 PM
Thanks for the responses. Well the tires are pretty much new even though the wheels are pitted so buying a whole new set up might be too costly. I might have to look into the different options.
Old 06-28-2012, 03:49 PM
pdxrealtor's Avatar
You sure it's your tires? 325/60 is only 35.2 inches high and 12.9 inches wide.
The 20" rim is not your problem. You can get several size tires to fit that rim if it is your tires.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 06-28-2012, 10:15 PM
mbdougl's Avatar
Good Information about tires:
http://www.*******club.com/tech/h2_tires.html
Old 06-28-2012, 10:16 PM
guruerror's Avatar
LOL! *********!
HUMMER + X is a bad word as far as the forum software is concerned.
CNTRY
DTOM
Old 06-28-2012, 10:17 PM
mbdougl's Avatar
insert "*******" for the asterisks
Old 06-28-2012, 10:18 PM
guruerror's Avatar
Nope...LOL!
Here's a work around; click this: http://www.google.com/#hl=en&sclient...=1920&bih=1096
...and select the first link on the page.
CNTRY
DTOM
