Old 07-05-2012, 03:33 AM
Egan's Avatar
Egan Egan is offline
Egan is on a distinguished road
Post Corvette servo install
Installing the Corvette Servo in the H2 tranny:
The idea behind this part is that it firms up the 1-2 shift in our transmissions. For $18 shipped, I figured what the heck and ordered it from: http://www.oregonperformancetransmis...de=NTP-K51828C
The installation itself is easy enough and took about an hour.
Step 1: Remove the heatshield between the cat and the side of the tranny.
Once removed, you?ll see the servo:
Old 07-05-2012, 03:34 AM
Egan's Avatar
Default Re: Corvette servo install
Step 2: Push in the servo cover, compressing the spring, and remove the clip that holds the cover in. I used the wonder bar:
With the clip out, you can use pliers to pull the cover out. It will likely get stuck on the blue seal. The kit comes with a new blue seal, so I cut the old one out:
Old 07-05-2012, 03:35 AM
Egan's Avatar
Step 3: Pull the cover out, exposing the 4th apply piston
Pull the 4th apply piston out, exposing the servo assembly:
Egan's Avatar
Step 4: Pull the servo assembly out. There is a spring on the back side that will likely fall out:
That spring was resting on the protrusion seen here. Make sure you put it back on before sliding the new servo back in:
Old 07-05-2012, 03:36 AM
Egan's Avatar
Step 5: Remove the clip, washer, and spring from the 2nd apply piston. Simply push down on the washer and spring and pop the clip out:
Then simply slide the shaft out:
Old 07-05-2012, 03:37 AM
Egan's Avatar
Step 6: Disassemble the 2nd apply piston assembly. Start by compressing the cover (I used a c-clamp):
Once compressed, remove the circlip and uncompress the cover:
Take the spring out of the existing servo housing and move it over to the new one:
Old 07-05-2012, 03:38 AM
Egan's Avatar
Step 7: Reassemble the servo. Start by compressing the housing cover again and reinstalling the existing circlip.
Unfortunately, I was only born with 2 hands, so I had to get some help:
Next reinstall the shaft:
And then slide the new housing over the piston. Make sure the seal is lubricated and fully seated:
Next install the new red seal on the piston and reinstall the spring, washer, and clip to hold it all together:
Old 07-05-2012, 03:39 AM
Egan's Avatar
Step 8: Reinsert the servo assembly into the transmission – make sure that spring that fell out in the beginning is in:
Step 9: : Reinstall the 4th apply piston:
Install the new blue seal on the cover and push the cover in place. Again compress the cover and reinstall the original clip. I need an extra hand to do this. I also had to reseat the assembly a couple of times to get it to fully seat.
Don’t forget to reinstall the heat shield after you check for leaks and proper operation.
Old 07-05-2012, 03:41 AM
Egan's Avatar
First impressions are a much longer, smoother shift between 1 and 2. I'll reassess after the 12 mile drive to work tomorrow.
Old 07-05-2012, 04:15 AM
[__--MUD--__]'s Avatar
These guys have some pretty good **** for our trannies...few other things you can do w/ out yanking it out for 2-3 & OD. Plus 4l80 conversion kits if you realy want to say screw it.
http://www.transmissioncenter.net/4l60e.htm
Old 07-05-2012, 07:37 AM
pdxrealtor's Avatar
Another great write up! This , to me, was worth paying 45.00 to have done.
Much firmer shifts. 1st lasts much longer.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 07-05-2012, 10:55 AM
jsbihn jsbihn is offline
Moderator
MUD
There is alot of good stuff on there and most of it is surprisingly inexpensive
I assume when you refer to the 2-3 & OD, you are talking about overdrive billet servo?
Old 07-05-2012, 05:26 PM
Hellz Hellz is offline
well i tried to give a shot at this today, and i am stuck at step 1...well i dont have a heatshield to remove...
i can not get the housing to compress to remove the clip.
when you compress it, is the amountit compresses noticable, or are we talking thousandths of a inch here?
i tried using a pry bar.. that wasnt working and moved up to a crowbar.
i can get leverage on it, it just is not moving at all.
any thoughts?
Old 07-05-2012, 07:24 PM
Egan's Avatar
any thoughts?
It moved a good 1/8 inch at least, if not 1/4 inch.
Old 07-05-2012, 08:17 PM
ya, its not moving at all.
i tried putting a socket in there and trying that route... no luck
i have an open shot at it from the wheel well, and tried using a hammers handle and slapping it to break it free.. still no luck..
going to drown it in some WD40 and let that sit for awhile
Old 07-05-2012, 09:09 PM
Egan's Avatar
This servo is pretty far from the wheel well. I was standing in between the arms of my lift when I was directly underneath it, and the forward arm is behind the front wheel by at least two feet.
Old 07-05-2012, 09:18 PM
pdxrealtor's Avatar
I was thinking the same thing, Egan. I actually went outside to check it out and it seems possible with the front wheel and fender well shroud off.
However, it doesn't look easy. With your second guessing combined with the fact there was no heat shield... Hellz.. are you sure you're in the right spot?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 07-05-2012, 09:51 PM
well it is some distance away.. but i do have clear access to it fromt eh wheel well.. i just wont have any leverage and would most likely need a 2nd person to help with it.
this is fromt the passenger side.
Old 07-06-2012, 04:42 AM
pdxrealtor's Avatar
Well goddamn.,.
Can you use a pipe, like a breaker bar, to get a good seat around the hump then tap it loose with a heavy hammer?
Sounds like it just needs to be loosened up and then you'd be good to go.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 07-09-2012, 03:44 AM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Glad to see this write up that is Hummer specific! Thanks!
