Old 07-07-2012, 07:38 PM
jsbihn jsbihn is offline
Moderator
Default LS6 or LS7 cam?
Could a LS6 or LS7 cam fit and work in our engine?
And if so would it be beneficial? (ie. more hp or more torque)
I am wondering since basically i understand this is just the iron block version of a Vette engine
Old 09-12-2012, 12:52 AM
USMC_Buckaroo's Avatar
USMC_Buckaroo USMC_Buckaroo is offline
USMC_Buckaroo is on a distinguished road
Default Re: LS6 or LS7 cam?
Howdy jsbihn
I'd be curious to hear the answer to this myself.....had a teenage carbuilding pard' of mine who had a 'factory' LS7 Chevelle back in the day...saw that thing burn rubber in THIRD gear doin' about 50 mile an hour!
Sure most of you youngin's think that's BS.....but, you're forgettin' that we used to have REAL horsepower back then...from the factory
Buck.
Old 09-12-2012, 03:24 AM
[__--MUD--__]'s Avatar
Most of the lsx is interchangeable. If your going to do anything to the motor have room in the budget for a 4l80 tranny to back it up. The stock tranny is borderline as it is.
Check out performance trucks.net or ls1tech. Tons of people doing mods to their trucks over there, but the have truck transmissions capable of the power.
Old 09-14-2012, 02:23 AM
Mister Peebody's Avatar
Mister Peebody Mister Peebody is offline
Mister Peebody is on a distinguished road
Originally Posted by USMC_Buckaroo
Howdy jsbihn
Buck.
More like, bias ply tires. No traction. The era of the muscle car is now. That said, I'm sure the OP is speaking of the current LS6 (C5 Z06) and LS7 (C6 Z06) corvette cams.
To the OP, is you are gonna go thru the trouble of tearing into your motor, then you may as well get the most bang for the buck by installing a custom aftermarket cam. JMO
2005 Stealth Grey H2 Luxury - Billet and Carbon Interior, Custom Audio/Video, 22" Zinik wheels with 35" Nitto Trail Grappler M/T tires, HID headlights
Old 09-14-2012, 03:45 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Depending on how much lift and duration change you do may need custom programming as the manifold pressures are gonna change causing map sensor inputs to ecm to change your timing and fuel curves. Minor changes can be adjusted for with stock programming. Major changes will throw codes and run rich typically.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 09-14-2012, 02:04 PM
guruerror's Avatar
Originally Posted by Mister Peebody
...The era of the muscle car is now...
Hmmm...I'd have to disagree. The 'Return of the Pony Car' era may be upon us, but not the true muscle cars.
Muscle cars were big, full size vehicles that cranked out the HP...Chevelle, 442, Torino... We aren't likely to see another true muscle car era again thanks to the price of gas and the 'huggers.' Give us back the Impala SS and the Crown Vic Interceptor and that would be a good start; then maybe to do up an SRT-10 version of the 300 or the Charger...hmmm.
Mustang, Camaro, Challenger...they're back and they're pretty bad, but their still just pony cars in my book.
CNTRY
DTOM
Old 09-19-2012, 03:02 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
Keep in mind that LS6 (and LS7) cam was designed for a lightweight car... (my LS6 Z06 weighs under 3100lbs). While you may pick up power on the top end I would be leary of losing any low end grunt in a 6700lb. truck. Just something to think about. I think you would be best having a custom grind cam spec'd out.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
