Old 07-08-2012, 05:31 PM
pdxrealtor's Avatar
Default Brake question - Does your pedal pulsate one time?
Does your brake pedal pulsate one time upon pressing it quickly? At the top of the stroke....
You'd tap the pedal quickly, not necessarily with a lot of pressure and get a pulse or otherwise could be described as a slight bounce back before continuing down in its path.
If you all could check and let me know I'd appreciate it.
Mine used to and now it does not. Yesterday the truck didn't want to stop in relation to how much pressure was being applied to the pedal.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 07-09-2012, 12:04 AM
racer24 racer24 is offline
racer24 is on a distinguished road
Default Re: Brake question - Does your pedal pulsate one time?
It's the ABS brakes. They all pulsate when you push them down hard.
Old 07-09-2012, 06:23 PM
pdxrealtor's Avatar
As I described above?
What I'm talking about is a SINGLE pulse or bounce back and can be done in park.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 07-10-2012, 04:02 AM
pdxrealtor's Avatar
Anyone?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 07-11-2012, 05:29 PM
pdxrealtor's Avatar
Would a few of you please tap your brake pedal next time you're in your truck, and let me know if you get what I described above?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 07-14-2012, 01:42 PM
I tried it and nothing. Nothing you describe. Might have the booster going bad.
Old 07-15-2012, 10:27 PM
pdxrealtor's Avatar
Thanks for trying it out.
I think what might be going on is unrelated to the brake pedal action I describe above. This started after the tire company put the new wheels on. They cleaned up the calipers with what I assume was brake cleaner.
I'm thinking the calipers were so dirty that it effected the abs sensor and the problem I'm having is the abs is wanting to kick in too early.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 07-16-2012, 01:18 AM
VegasMike VegasMike is offline
VegasMike is on a distinguished road
If you think it's the ABS, can you remove the ABS fuse from the fuse box and see if the problem goes away?
I have no clue if that will cause an engine light or anything, maybe someone can confirm or deny that.
Old 07-16-2012, 01:33 AM
pdxrealtor's Avatar
I did take the ABS fuse out, and the TC and ABS light comes on. The symptoms are the same but happen much later into pedal depression than when the fuse is in and the sensor kicks in prematurely.
I'm putting on new hubs next weekend, which have the sensors. So we shall see.
I'll tell you what... Our Acura MDX has 80k on it and never had more than an oil change. I don't see how you spend 60k on a truck that starts ****ting out in 50k. Blows my mind...
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
