07-15-2012, 11:57 PM
Ready to buy new front end- Need a couple quick answers
I'm going all MOOG.
Idler
Idler Pivot
Pitman
Lower ball joints, only because I ripped the boot on one side
Timken Hubs
I'm running stock sized tires with 8.5" Rockstar rims (+offset w/in HUMMER spec)
Should I get the Cognito support kit?
Pitman arm- are all H2's a 3 groove?
Need to order tonight ASAP so any input is greatly appreciated!
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
07-16-2012, 01:29 AM
Re: Ready to buy new front end- Need a couple quick answers
Well.... Ya'll weren't quick enough so I ordered both the 3 and 4 groove and will send one back.
I ended up ordering from Rock Auto. Even before the coupon code of 8DC7D212FF36 gave me 5% off it was still cheaper than ordering from Amazon.
Still need to know opinions on the Cognito kit. Now's the time.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
07-16-2012, 02:53 AM
Yep, order the support kit. That damn front end needs all the help you can give it, even with the stock size tires.
07-16-2012, 03:58 AM
Cool. Thx for advice.
Anyone else care to reinforce this 225 dollar purchase?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
07-17-2012, 03:11 AM
$225 is a steal man if you are getting everything for that. What was your final list again? I need to upgrade my front end too....
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
07-17-2012, 03:23 AM
LOL.. that did look confusing didn't it.
I was referring to JUST the purchase of the Cognito support kit... it's 225.00.
All the parts listed, minus the Cognito support kit, came to 646.00. Got it all from Rock Auto with the 5% off coupon.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
07-17-2012, 11:09 AM
What he said. You're going to be in there doing the work anyway, or at least having someone do it for you. Might as well get the support kit and be done with it.
2004 white H2 SUV lux
07-17-2012, 06:28 PM
You definately want to double capture that link.
07-17-2012, 08:18 PM
Sucks that this has to be done at 50k without the need for another 225.00 part. I should have just ordered cheaper idler/pitman to help pay for the support kit.
Good Lord
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
07-17-2012, 09:03 PM
Just ordered the support kit from Off Road Warehouse. 225.00 shipped.
FYI- Cognito said to install this before your alignment, in my case since I'm doing other front end work, or get an alignment after this part is installed.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
07-17-2012, 10:45 PM
Depending on the mechanic, you may or may not need the alignment. After mine was installed he checked the alignment and the front didn't change from the last time I had my mechanic do the alignment.
07-18-2012, 03:37 AM
Good to know. If you have the resource that makes you feel good about it and your 2000 + dollar tires than all the better.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
07-18-2012, 02:26 PM
I have most of these same parts sitting in a box ready to go in (Moog Pitman & Idler, Cognito Support Kit). Are there any special tools required to pull/install the Pitman and Idler?
07-18-2012, 03:51 PM
for the pitman arm, you can pick up/rent a puller at autozone.
i didnt use one on mine. i remember i banged on it for awhile with a hammer, and a ball joint remover. i just remembered that it sucked and took some time. so might be in your interest to pick up a puller and make it easier on yourself
07-18-2012, 06:16 PM
I've read to use the puller you need to loosen the gear box, FYI.
Mine looks rusted to ****. It spent the first 24 k of its life in Orlando, right by the beach and all it's salty air. I'll probably end up just grinding mine off with a grinder.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
