Old 08-13-2012, 01:10 PM
ryaleon's Avatar
ryaleon ryaleon is offline
ryaleon is on a distinguished road
Default So what can be interchanged?
Basically I'm just curious as to what parts if any can be interchanged between the 6.0 H2 and the 6.2. Trim pieces, seats, gauges, mirrors, so on and so forth. Any help would be appreciated.
Old 08-13-2012, 02:45 PM
[__--MUD--__]'s Avatar
Default Re: So what can be interchanged?
You need a hollander manual.
Old 08-13-2012, 03:06 PM
guruerror's Avatar
Exterior...from what I can tell, almost everything. One thing to note, the front grills can be swapped, but they must be done as a set (upper and lower together). The lower grill from an 03-07 will not fit on the upper grill from an 08-09 and vice versa. The clip slots do not line up.
Interior...almost nothing related to the dash, gauges, trim, unless you are doing a complete swap, but then you might even run into wiring issues with harnesses not being long enough, plugs being different, etc. The newer H2s might even use the CAN bus...I'm not sure about that though.
CNTRY
DTOM
