08-14-2012, 03:57 AM
KC Backup Lights
Needing more light when backing up, I ordered some KC KCC-517 backup flood lights to mount on the back of my Gobi SUT bed rack. Summit had them for a good price and their warehouse is not too far away (far enough to be tax free, close enough to make ground shipping 2-day shipping).
I had to increase the mount hole size on the Gobi rack a couple of steps so the large KC bolt would go through.
Mounted:
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Kryptonite Swaybar End Links
Traxda Keys
Traxda Rear Coil Spacers
Bilstein Shocks
TruCool Tranny Cooler
Corvette Servo
Gobi Ranger Roof Rack
Gobi Bed Rack
Pioneer AVIC-Z110BT: Nav, Bluetooth, iPOD, Backup Camera
Valentine 1 w/ Blend Mount
ATX Artillery 17x9 Teflon
Toyo Open Country MT 37x13.5x17
Re: KC Backup Lights
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Traxda Keys
Bilstein Shocks
Corvette Servo
Gobi Bed Rack
#1, #2, and #5 are fed from battery power and #3 and #4 are accessory power.
The battery power is off an accessory fuse panel I installed after running hot and common ground through the firewall grommet:
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Traxda Keys
Bilstein Shocks
Corvette Servo
Gobi Bed Rack
08-14-2012, 03:58 AM
The switched power for the backup lights, airhorn switch, and airhorn compressor run through a grommeted hole I made in the floor:
The backup light power routes back to the driver's taillight. KC was kind enough to include a relay that allows the lights to run off the backup lights or the switch I installed in the cab:
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Traxda Keys
Bilstein Shocks
Corvette Servo
Gobi Bed Rack
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Traxda Keys
Bilstein Shocks
Corvette Servo
Gobi Bed Rack
08-14-2012, 04:00 AM
I can still load the rack up without interfering with the lights. This is a really slick feature on the Gobi rack.
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Traxda Keys
Bilstein Shocks
Corvette Servo
Gobi Bed Rack
08-14-2012, 11:26 AM
looks good, I plan on mounting my switches in that same spot just need to get them ordered.
I should post pics on here of my custom light brackets I made for my stealth....
08-14-2012, 02:20 PM
Are you running all power through the switches for the accessories, or are the switches wired to relays?
08-14-2012, 02:32 PM
For the yet to be ordered/installed front lights, I will probably use a relay similar to the backup lights. Those switches get battery hot so I won't have to turn the key to fire the lights/relays up.
The airhorn switch (to switch between stock horn and airhorn+stock horn) won't need a relay and I won't put one on the compressor switch either. All 5 switches are rated for 30 amps.
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Traxda Keys
Bilstein Shocks
Corvette Servo
Gobi Bed Rack
08-14-2012, 02:35 PM
I love that they come on when you're in reverse or you can turn them on manually. Great for off roading as well as the duechey behind you with his high beams on...
08-14-2012, 02:37 PM
View from behind:
View from the front at 5:45am before heading to work (what happened to summer?):
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Traxda Keys
Bilstein Shocks
Corvette Servo
Gobi Bed Rack
08-14-2012, 06:03 PM
I like the way you mounted the switches. Looks close to OEM, but I wish the switches themselves were prettier. Maybe if they looked a little like the Ford Raptor switches it'd be better.
But still... really like the way you mounted them! Good job
08-15-2012, 05:26 PM
Some nice looking switches. You can get any design lasercut in them.
https://otrattw.com/index.php
