new to me h2 radio issues
Re: new to me h2 radio issues
Jake666,
Sounds based upon your description that theres someing wrong with the radio itself, not the system. It could be anything from any of the buttons malfunctioning to something more internal. My suggestion is to try another OE 6Disk radio and see if the same issue duplicates itself. If you try this and it works just fine with another OE radio, then it was the old radio itself. If the problem continues, then its in the system. You will have to rule things out. I have an OE 6 disk here for sale on my shelf if you want to try it.
The other alternative would be to just go aftermarket but like you said, you could run into interfacing issues.
fyr145
If ya just want to install a factory headunit back in ya can have my old one.
It worked fine when removed. I went with a Kenwood DNX-6960. Great unit has bluetooth,dvd,and garmin based gps.
http://www.elcovaforums.com/forums/s...ad.php?t=42693
Thread Tools
Search this Thread
