Old 09-15-2012, 02:25 PM
SMITH23H2SUT's Avatar
SMITH23H2SUT SMITH23H2SUT is offline
SMITH23H2SUT is on a distinguished road
Default Auxiliary power line ( POWER PLEASE )
I'm sure with all the HUMMER owners on this forum, someone has got to know the answer to this one. Where exactly is the best place to drill a hole for the power cable, through the fire wall? I read in a thread on "Floorboards Wet", that if it's too low water will get in. Where is the best location to pass the line through.Thank you for any answers on this.
Old 09-15-2012, 06:13 PM
[__--MUD--__]'s Avatar
Default Re: Auxiliary power line ( POWER PLEASE )
Old 09-17-2012, 10:28 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
After going through the hassle of passing a couple of wires through the existing grommet behind the hydro-boost unit and needing an opening for a whole lot more wires (no less than 6 additional switches, antenna wire for the CB, etc.), I decided to drill a half inch hole through the firewall. The location I chose was based on the easiest access from both sides of the firewall as well as the ease of actually drilling the hole without fear of the drill bit hitting something vital. I wasn't concerned with fording any deep rivers! The pics tell the story:
Inside the cab:
View from under the hood:
Here's a few pics of some of the switches as well as wiring going to the roof:
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
Old 09-18-2012, 11:14 AM
Thank you both for responding. I will try Advice #1 and see if I will be able to get a 4AWG cable through, if not I will try Advice #2 and drill a hole through the floor board. I'd rather go with Advice #1 just for the fact that HUMMER's are a species that are about to go extinct, especially SUT's and I want to keep it " River Riding" capable.
Old 09-19-2012, 04:27 AM
pdxrealtor's Avatar
a 4 gauge wire will fit through the steering shaft boot with no issue if you don't have a ton of other wires going through already.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 09-19-2012, 02:24 PM
Yea, I've seen posts where guys ran their cb cable w/ the screw on connector attached right through that. Plenty of room there.
