Old 10-03-2012, 01:57 AM
guruerror's Avatar
Default Limb Riser
I know some of you are running limb risers on their H2s
Post up some pics...I'm working on a custom setup, but could use some additional ideas.
CNTRY
DTOM
Old 10-03-2012, 03:49 AM
[__--MUD--__]'s Avatar
Default Re: Limb Riser
I'm putting some on mine...long list. Look for the mackinaw island summer hummer trip threads. Bunch of guys had them, a lot of pics. They might be on one of the other sites, local section, great lakes/Midwest/Michigan.
Old 10-03-2012, 09:40 PM
KT2T's Avatar
KT2T KT2T is offline
KT2T is on a distinguished road
Here is a pic of mine. They have a stainless carabiner at the top end that feeds through a hole in the aluminum angle running along the roof crossbars. At the lower end, there is another stainless carabiner that runs through one eye of a turnbuckle. The other eye of the turnbuckle is attached via stainless carabiner to a u-bolt that's attached to the brushguard. When not in use, I loosen the turnbuckle, detach from top then bottom, roll 'em up and store in the front door pockets.
The aluminum rails up top are 1.25" x 1.25" x .25" and work great for taking the limbs off of the risers and letting them ride all the way to the back above the crossbars. They also work great as anchors for tying stuff to the roof and handles to grab when standing on the steps.
Mike
2000 HUMMER HMCS, kevlar flat black, Rubber Duck lift, Predator stage 3 kit, Predator (Wilwood) Big Brake kit, a work in progress...
2008 H2, graystone, air suspension (DELETED), U-steps, SMA brushguard w/valance (DRLs replaced by PIAA 520s), black taillight guards/locking fuel door/roof crossbars (x4), Cognito UCA/pitman-idler, Bilstein shocks, Rancho steering stabilizer, Kryptonite tie rods, green keys, Fuel D525 20" Revolver, 37" Nitto Ridge Grappler
Old 10-05-2012, 02:37 AM
guruerror's Avatar
Interesting idea KT2T...
I'm working on fabbing some brackets that will attach to the roof rails and protrude past the windshield. Once I get them cut and powder coated I'll post up some pics.
CNTRY
DTOM
Old 10-06-2012, 10:23 AM
NJ H2's Avatar
NJ H2 NJ H2 is offline
I attached the Limb risers from the SS GOBI Stealth rack to my SS Manik Brush Guard/Push Bar. A picture is worth 1000 words so here is 3000 words!
NJ H2's Avatar
Old 10-06-2012, 10:25 AM
NJ H2's Avatar
Old 10-13-2012, 10:22 PM
guruerror's Avatar
Thanks to everyone who posted up pics...
I just finished mine this afternoon...my emphasis was on 'tool-free, quick connect/disconnect.' I found these wonderful little things at Home Depot in the plumbing section called 'clevis hangers' (used to hang pipe from the ceiling) that give you an excellent quick connect to the brush-guard.
Since my rack is 'ultra-stealth' and sets back further than some, I couldn't use the rack as a roof-mounting point, so I had some roof rail brackets fabbed out of 1/4" steel plates which I proceeded to mod until they fit my needs. Here's the pics!
Dimension of the brackets:
Put a little bend on the end:
A little paint, padding, and a spacer:
Mounted:
That wonderful 'clevis hanger' that I mentioned earlier:
Turnbuckle setup:
Roof bracket connection:
Finished product:
When not in use, the brackets can be loosened and slid back so the arms do not extend so far out from the windshield.
Again, thanks to everyone who posted up pics and ideas!
CNTRY
DTOM
Old 10-15-2012, 04:14 PM
PaHumBug's Avatar
PaHumBug PaHumBug is offline
Looks great man!
Old 11-19-2012, 01:11 AM
HUFFADDER HUFFADDER is offline
HUFFADDER is on a distinguished road
PM sent to you Guruerror.
Old 11-19-2012, 01:40 AM
guruerror's Avatar
None received...
CNTRY
DTOM
Old 11-19-2012, 02:00 AM
wasp1971's Avatar
wasp1971 wasp1971 is offline
wasp1971 is on a distinguished road
Not to sound ignorant but what is the purpose of the cables running from the rack to the brush guard?
Old 11-19-2012, 02:02 AM
guruerror's Avatar
Basically, to lift limbs and branches up over the truck without having them smack into the windshield.
CNTRY
DTOM
Old 11-19-2012, 04:18 PM
Originally Posted by guruerror
None received...
Tried again...Lol
Old 11-21-2012, 07:56 AM
NJ H2's Avatar
Super Heavy Duty Limb Risers ... more like "Tree Risers"!!
Old 11-21-2012, 01:59 PM
guruerror's Avatar
LOL! I'll have to take another pic of how they turned out...I found the same style clevis hanger in stainless steel and replaced the bolt and wing nut with a yellow zinc lock pin.
Gonna test them out at Rausch Creek, PA the first weekend in Dec...
CNTRY
DTOM
