Old 11-06-2012, 11:12 PM
devilsfan's Avatar
Default "Service 4WD" plus burning smell?
New problem - my "Service 4WD" keeps coming up. I've been able to clear it in the past by changing into high/low gear for a moment, but this time it keeps coming back on - but only after I've run the truck for a while, never on start up. Once I shut the truck off after running it, I've been noticing a burning smell from the front end, like meltiing plastic. Ideas?
Old 11-07-2012, 01:37 AM
[__--MUD--__]'s Avatar
Default Re: "Service 4WD" plus burning smell?
Didn't you put headers on this summer? If so, i'd look to see if anything is touching them now.
Old 11-07-2012, 07:00 PM
devilsfan's Avatar
Nope, headers are in the clear. I did see one of the wires to the headlights touching the engine though and resecured that. But on the way home today, it was more of a brake-pad smell and super strong. There was supposedly an industrial fire in that area tho, I hope that was all it was and nothing new!
Old 11-07-2012, 09:32 PM
Ken Bowers Ken Bowers is offline
Ken Bowers is an unknown quantity at this point
I also have the "service 4WD" alarm after driving awhile. I received a hint that it may be due to low battery voltage, so I am going to do a full charge tonight. I will report later.
I have no ideas about the smell.
Old 11-07-2012, 10:42 PM
guruerror's Avatar
The one and only time I got the Service 4WD it ended up being a faulty transfer case shift control switch (15127829).
15 in the diagram: http://parts.nalleygmc.com/showAssem...modelYear=2005
CNTRY
DTOM
Old 11-07-2012, 11:36 PM
devilsfan's Avatar
Smell is gone now, that's a good thing.
Been watching for my error message - it's very intermittent, and when the "Service 4WD" comes on, the locker button (top round button) starts flashing. Then the message goes off and the light stops. This will do this maybe every 10-15 mins when I'm driving, and lasts for maybe a minute.
Old 11-07-2012, 11:40 PM
Hellz Hellz is offline
check the fluids in the T case?
Old 11-08-2012, 03:07 PM
HummerJim's Avatar
15 in the diagram: http://parts.nalleygmc.com/showAssembly.aspx?ukey_assembly=392529&ukey_make=1 027&ukey_model=14605&modelYear=2005
+1
Had the exact same issue when the H2 was new. It would come on randomly and then go off, but it started staying on and Lynch replaced the switch in 2007 and not a single SERVICE4WD since then. Problem solved.
Old 11-10-2012, 10:55 PM
H2Much's Avatar
H2Much H2Much is offline
H2Much is on a distinguished road
I've had this too. Can't remember it if was a switch or a sensor, but it was one of the two. Same thing as the other guys, when I had it replaced, the light never came on again.
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
Old 11-10-2012, 11:26 PM
devilsfan's Avatar
Never came up all day yesterday. Odd.
Is this the $700 switch that needs to be replaced? If that's the case, I'll just deal with the blinking light.
Old 11-11-2012, 04:51 AM
guruerror's Avatar
I think mine was about $75...I installed it myself to save the hour labor in taking the console and dash apart.
CNTRY
DTOM
