Old 12-07-2012, 10:28 PM
Hellz Hellz is offline
Default rear ABS sensors removal help
been having ABS/TC lights on, on my dash for some time, and today i decided to do somethign about it. this all started right when i regeared from 4.10 to 4.88
anyways, i doubt it is my front sensors, but i have spares to do those anytime (37 inch tires loves hubs)
rear sensors
i see 1 screw to hold it on, but having a bitch of a time pulling it out.
driver side one seemed fine, but didnt remove
pass side bolt was missing, but same as driver.
is there a trick to removing these sensors?
rear shocks removed would help, but 30 degrees outside, not that much motivation.
but would appreciate help on removal
Old 12-08-2012, 02:48 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: rear ABS sensors removal help
They just slide right out. Well maybe if its new. Try spraying them with penetrating fluid a couple times a day for at least 2 days. Then you just have to twist and pull until they come free. Also can use a small flat blade behind mount bracket and lightly pry while twisting. They are a real bitch sometimes but with patience you will get them out.
1998 Chev Z71
2007 Chev Trailblazer SS
