Old 12-09-2012, 12:52 AM
Easy Ed Easy Ed is offline
Default Water Pump
Been having coolant showing up on the garage floor so after crawling around the truck I see that the gasket for the water pump on the passenger side looked to be leaking. After searching around the interweb it seems to be "standard procedure" to go ahead and replace the water pump and gaskets versus just the gasket. After getting it apart I see where the problem was at, the o-ring had moved from its sealing surface leaving just the gasket material to try and seal it off. After all said and done I am thinking I could have just replaced the gasket, the pump does not have anything showing in the "weep hole" and there is no play in the pump shaft, but figured WTF go ahead with pump and gaskets while I was at it and had bought them already.
Attachment 54135
Attachment 54136
Attachment 54137
Attachment 54138
Old 12-09-2012, 04:58 AM
Hellz Hellz is offline
Default Re: Water Pump
how long did the process ake you to remove and replace?
thoughts bout going to a electrical water pump?
any issues or advice?
Old 12-09-2012, 02:21 PM
Took me four hours but that was because I wanted to make sure everything was done right, least amout of anti-freeze on the floor, torque specs used when putting parts back on, ect.
To replace the pump.....
Had to take a big Cresent wrench and a plastic mallet to bust the fan nut loose. One guy that did a youtube video on changing the pump in a pick up used a air chisel to bust the nut loose, he put it flat against a corner of the nut and it did come loose pretty easy but that was not something I had in my tool box.
The radiator shroud comes out pretty easy after the fan and top radiator hose is removed, two bolts at the top and one clip to hold a couple metal lines that I think come from the tranny. Caution on putting it back in, the bottom lip goes on the inside of the bottom support.
I also removed the belt tensioner for the long belt before pulling the pump. (remove AC belt only).
Here is some more pics of draining the coolant (don't remove the petcock all the way or it will make a mess) and everything but the pump removed.
Hope it helps, Good luck Hellz, Ed
Attachment 54140
Attachment 54141
Attachment 54142
Old 12-11-2012, 03:58 PM
HummerMann's Avatar
Nice photos, Ed - thanks! That project is not long off for my 110,000 mile H2 and mine is on the passenger side gasket also. I've been tolerating the slow drip so far.
Hummer, like nothing else
Old 02-04-2014, 07:38 PM
H2inMD H2inMD is offline
H2inMD is off the scale
as always, nice write up Ed.
My mechanic wants to remove the hood to do this. Looks like the hood is 4 bolts, but are we going to have trouble realigning and not damaging it in the process.
comments?
Old 02-04-2014, 09:42 PM
No need to remove the hood, would just add more time to get the job done
Ed
Old 02-06-2014, 01:34 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
It would allow for definite easy access to the front of the truck but the size of the thing I wouldn't attempt it!
Old 02-06-2014, 04:10 PM
thats what i was thinking. Taking the hood off would make it easier to get to stuff, but and its a BIG BUTT.......
I think the effort in removing the hood, not damaging it and then reinstalling it
would just create a different painful scenario.
