Old 12-11-2012, 02:09 AM
iwillnc's Avatar
iwillnc iwillnc is offline
iwillnc is on a distinguished road
Default Wiring diagram or info for liscense plate remote location
on 2003 H2's you could get the dealer installed rear tire carrier which also included a setup to move your liscense plate to the driver side.
I'm having a problem where I'm not getting any juice, my ground is fine, and I've tested 3 light bulbs. But the postive just gets so jumbled up that at the time I didn't have the time to track it, can any one give me some info on how this works?
Oh and checked fuses didn't see any burnt ones, though may not have checked the correct ones, but I didn't see anything.
Old 12-14-2012, 12:42 AM
iwillnc's Avatar
Default Re: Wiring diagram or info for liscense plate remote location
really need this
Old 12-14-2012, 01:18 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Heres the factory schematic
1998 Chev Z71
2007 Chev Trailblazer SS
Old 12-14-2012, 01:24 AM
HUMTECH's Avatar
License Plate Light Wiring Instructions
1. In front of rear bumper underneath vehicle on driver side, locate cluster of three plugs. The white
plug housing should have no existing wiring.
2. Remove the white plug housing from receptacle by pushing in the tab and pulling down.
3. Remove the wire retainer from the plug housing.
4. Remove the two orange plugs as shown in drawing.
5. Push terminal ends for tag light into plug as shown in drawing.
6. Replace wire retainer.
7. Route plug housing and wire back to receptacle and plug in firmly to engage tabs.
8. Use provided wire ties to secure excess wire.
Photo below shows finished installation.
9. Install license plate
10. Turn vehicle lights on, check to see that license plate light functions
1998 Chev Z71
Old 12-14-2012, 01:41 AM
iwillnc's Avatar
As always many thanks Humtech, these are for the after market reposistion I assume?
Old 12-14-2012, 02:04 AM
HUMTECH's Avatar
Diagram is the factory wiring the truck came with. Instructions below are the ones we would get with the SMA tire carrier kit. For some reason it would not let me copy and paste the pictures. Google hummer sma tire carrier and you should be able to find what ya need
1998 Chev Z71
Old 12-14-2012, 02:09 AM
iwillnc's Avatar
let me rephrase it's not an aftermarket tire carrier but rather the dealer installed one, it was sold new with it in 2003
Old 12-14-2012, 02:33 AM
HUMTECH's Avatar
In 2003 the only tire carrier was the sma one. I installed many of them prior to delivery. At the time GM didnt offer an outside spare tire carrier.
1998 Chev Z71
Old 12-14-2012, 02:35 AM
HUMTECH's Avatar
Is this what yours looks like?
1998 Chev Z71
Old 12-14-2012, 02:40 AM
iwillnc's Avatar
Oh I see, yes it does, and I did look online I could find any diagrams or wiring templates or the such.
Old 12-14-2012, 02:41 AM
iwillnc's Avatar
Not to go off topic but how exactly does the shaft go into the hinge? My tire carrier is so stiff I have to put some real muscle into it to get it to move either way.
But back to wiring
Again hate to go off topic but
http://www.elcovaforums.com/forums/s...ead.php?t=2608
How many of these have you corrected?
Old 12-14-2012, 02:43 AM
HUMTECH's Avatar
Thats the sma carrier. Look under the truck behind the rear bumper and you should find the wire that was connected for the light. Cant remember what fuse it runs off though been a long time since ive seen one in the shop
1998 Chev Z71
Old 12-14-2012, 02:46 AM
HUMTECH's Avatar
That was one of the reasons they quit making them. too many warranty claims on the pivot seizing up. Try spraying it with good penetrating spray once a day and working it back and forth
1998 Chev Z71
Old 12-14-2012, 02:50 AM
HUMTECH's Avatar
Its a steel shaft that slides down into a brass bushing
1998 Chev Z71
Old 12-14-2012, 02:53 AM
iwillnc's Avatar
Yea my brass bushing cracked apart real pia, but doesn't that tsb call for some pieces to be replaced to correct the problem
Old 12-14-2012, 02:56 AM
iwillnc's Avatar
Oh I see, I do like the carrier in the way it is seperate from the tow hooks unlike the new ones, but I've planned everything that I do around the basis that my rear door doesn't even exist the majority of the time lol.
But yea.
Anyways so you don't remember what the hot wire connects to/ splices into?
Old 12-14-2012, 02:57 AM
iwillnc's Avatar
Or I mean the brass bushing on the connecting T handle cracked, not on the hinge/pivot side.
Old 12-14-2012, 05:23 AM
HUMTECH's Avatar
If it was installed as per directions it should pass through the rear plastic bumper fascia. From there follow it to where it terminates and check for power at that point. I would be willing to bet power is there and problem is from where it terminates on the truck to somewhere towards the light itself. I will try to locate where the fuse is for ya but info is foggy on aftermarket installed parts
1998 Chev Z71
Old 12-14-2012, 05:26 AM
HUMTECH's Avatar
You could have someone or yourself drill the brass bushings out and install new ones, or plastic/neoprene bushings to match. Would work much better than brass.
1998 Chev Z71
Old 12-15-2012, 12:15 AM
iwillnc's Avatar
Alright figured it out, turns out that the power source for the license plate light is spliced into place from the trailer light hookup.
I could of swore I had checked that fuse twice at least, but sure enough when I checked it, it was blew.
I'm guessing it's probably from towing other peoples' trailers specifically ones that had, had hard lives and featured 1 out of 10 of the lights functioning lol.
Otherwise I'm at a loss why it would blow.
