Old 01-10-2006, 06:36 AM
nmikes nmikes is offline
nmikes is off the scale
Have a hard eye on that 12k lb. winch that rough country is advertising. Anybody have any information on this winch? I'm slightly concerned about the electrical draw this monster might have. Anything on the horizon for a beefier alternator or dual battery setup... anyone have any idea where you'd even stash a second battery?
Old 10-14-2006, 03:05 AM
Hal's Avatar
Hal Hal is offline
Hal is off the scale
Default Re: dual battery?
I'd like to see a dual battery discussion for the H3.
location?? how about above the passenger rear wheel on the inside where that storage area is?
Shadow Green 5-Speed/GREEN GRILLE/rear door AIR compressor/Factory Nav/Lux-Off Road Pkg/Sunroof/Roof & Grille Off Road Lights/Underbody Protection/Wet Okole seat covers/Husky floor liners/Black fuel door/No Chrome/'04 Grand Cherokee Overland/'94 Isuzu Rodeo 4x4 lifted.
Old 10-14-2006, 06:11 PM
There is a little space behind the air handler. But it would be tight. Maybe F5 could shed some light. You would need a bracket and a way to stay off the tubes that run under that space. It would take some engineering.
Problem with mounting in the back of H3 is spacial loss offerd resistance to front end. Requires heavy gauge cabling to compensate drops.
Old 10-14-2006, 07:00 PM
Never thought of it. If installing a winch, I would just recommend yanking the factory battery and installing a yellow top optima. Keep the motor running while winching and there should be no problem.
