Old 04-17-2013, 11:38 PM
Ken Bowers Ken Bowers is offline
Ken Bowers is an unknown quantity at this point
Default I bought a pressure washer for H2
We had a storm with blowing dust last week; leaving my H2 a mess. I bought a pressure washer from Home Depot ($186.) so I can wash it myself. 1900 psi.
The washer has a soap dispensor. I bought a wax additive (Turtlewax) that says to add an ounce to a gallon of cold water. I plan to put this in the soap dispensor!
Any thoughts or comments about this plan? If it works, I will be able to wash and wax my H2 (orange) on a regular basis.
Old 04-18-2013, 12:29 AM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Default Re: I bought a pressure washer for H2
I've always owned a pressure washer. My current one sound similar to yours. Personally I have never had great luck with the soap mixing systems if you want to call them.
It's basically just a hose that used the water pressure to siphon the soap in. I use a big soft scrubber on an extension pole and a 5 gallon bucket of car soap and water to wash. Pressure washer before to get rid of dust and after to get rid of soap.
Spray applied wax will do nothing. It may look shiny when you're done but it's not going to last.
Old 04-18-2013, 01:37 PM
PaHumBug's Avatar
PaHumBug PaHumBug is offline
I do it all by hand, like Lojac said, but without a pressure washer (only because I don't have one).
But dust? It will come off when you drive, or it if rains, or with a hose. It's not like it's tar, bugs, thick mud, or anything worth using a pressure washer for.
Old 04-19-2013, 12:31 AM
Arizona has a soil called "caliche". It forms a sticky glue when wet and drys to a hard mess. Wind and rain do not take it off.
I need a pressure spray to clean the roof too. I can't get up there.
I still plan to use the wax additive. I hope it does not goof up the pressure sprayer.
Old 04-19-2013, 12:45 AM
LoJac963's Avatar
Ken you're from AZ then I'm assuming? What part?
The wax additive shouldn't do anything to the washer. As for getting up to the roof, throw a GOBI rack and ladder on that bad boy!
Old 04-22-2013, 03:18 PM
Phoenix.
The pressure washer did not succeed in taking off the dust, even at 1800 psi! I had to hand wash it. But the wax worked very well-my orange hummer is beautiful!
