Old 05-16-2013, 04:47 AM
New York City's Avatar
New York City New York City is offline
New York City is on a distinguished road
Default How much would shocks cost?
How much would it cost to remove the entire air suspension system & add regular shocks?
I want to lower my hummer but was told the air suspension is not adjustable.
Old 05-16-2013, 06:18 AM
codered codered is offline
codered is on a distinguished road
Default Re: How much would shocks cost?
little over 300 bucks to do the rear suspension. you can buy the springs to replace the airbags from gmpartsdirect I believe.
Old 05-16-2013, 06:21 AM
So I can just have the air bags removed and add springs/shocks?
(and leave the air pump etc..?)
Old 05-16-2013, 06:29 AM
yep. you will have to disconnect the lines from the bag and then support the axle and cut the bags and pull them out. gm sells the springs with the rubber asborbers for the bottom of the spring. you can take the compressor out or leave it in depends on if you use it to fill your tires up or anything like that with the hook up inside for the hose. Then you will have to have the "service air suspension" comes across the bottom of the gauge cluster til you take it to a dealership to have the code removed.
Old 05-16-2013, 06:34 AM
Wow that actually seems pretty easy.
What would the dealer charge to remove the code? Any idea?
None the less, I greatly appreciate your reply & help!
Old 05-16-2013, 02:36 PM
Egan's Avatar
Egan Egan is offline
Egan is on a distinguished road
If you don't pull the sensors, you won't get the code.
I changed my airbags out for coil springs: http://www.elcovaforums.com/forums/s...ad.php?t=42682
The springs were $86 each through gmpartsdirect along with $24 for new isolator pads.
If you want to change shocks as well, you can get a complete set (front & rear) of Bilsteins for $330 from http://www.dmaxstore.com
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Kryptonite Swaybar End Links
Traxda Keys
Traxda Rear Coil Spacers
Bilstein Shocks
TruCool Tranny Cooler
Corvette Servo
Gobi Ranger Roof Rack
Gobi Bed Rack
Pioneer AVIC-Z110BT: Nav, Bluetooth, iPOD, Backup Camera
Valentine 1 w/ Blend Mount
ATX Artillery 17x9 Teflon
Toyo Open Country MT 37x13.5x17
Old 05-17-2013, 06:07 AM
Not sure on the price. I know the stealership close to me charges 75 bucks to scan and clear the codes in the computer.
Any other questions let me know!
Old 05-17-2013, 10:57 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Jesus at that rate you could buy a Aeroforce Interceptor gauge and clear them yourself and have an awesome gauge! I had duals in my GTO and loved them. I would check and clear codes just before going into emissions lol.
Old 05-19-2013, 07:41 PM
wasp1971's Avatar
wasp1971 wasp1971 is offline
wasp1971 is on a distinguished road
I changed out my air suspension with a kit I got that also had Bilstein shocks. The install was fairly easy and as far as the code goes there's a link on here somewhere that tells you how to get rid of it. That was easy too. I also totally removed the air compressor. That sucker was heavy! As for bilstein shocks I DO NOT recommend. It's like I have sponges on all four corners.
Old 05-20-2013, 08:51 AM
I might as well do it.
Selling the air suspension pump & what ever else is left should pay off for the job itself..
Thanks for the input guys.
(if anyone is in the nyc area that wants to do this for me, let me know so we can arrange something)
Thanks.
