Old 05-04-2006, 02:37 PM
RazM's Avatar
RazM RazM is offline
Howdy, I'm taking my monster for a 10K service and I'm wondering if an alignment is required with a tire rotation?
Old 05-04-2006, 02:45 PM
not required nor recommended, unless you've been seriously off-roading and/or hit something.
cestwick's Avatar
cestwick cestwick is offline
cestwick is off the scale
No. An alignment is not "required". IT's not a bad idea to check it ever 12k miles or once a year but not required. If you look at the tires and there is any abnormal wear (tread not flat and smooth) you should get the alignment checked.Tire Inspection and Rotation
Tires should be rotated every 5,000 to 8,000 miles (8 000 to 13 000 km).
Any time you notice unusual wear, rotate your tires as soon as possible and check wheel alignment. Also check for damaged tires or wheels. See When It Is Time for New Tires and Wheel Replacement for more information.
The purpose of regular rotation is to achieve more uniform wear for all tires on the vehicle.
'06 H3 Shadow Green, Adventure, 6 disk Monsoon, SMA brush guard w/PIAA lights, Rocky Road extreme rocker protection, roof lights(off road), lower grill lights(off road), Helo Maxx8 Black Wheels, 35" Cooper STT, Garmin I-Que M4 to get home.
