03-08-2004, 05:07 PM
Had my front skid plate sprayed with black Line-X (the picture is a little light)
Rich
04 H2 Adventure Series
Rich
03-08-2004, 05:53 PM
Looks great, but... the first time you catch it on rocks it's going to gouge a chunk out and possibly tear off a decent section unless it was thoroughly cleaned and primed before shooting it with Line-X. Ebven then, it's still very susceptible to tearing.
I cleaned, primed and shot mine with an industrial enamel that I bought at HomeDepot. I've slid it across gravel piles, sand dunes and gravel covered snow banks and it's none the worse for wear.
That was a great idea shooting it with the bolts in place.
March S&B is open
S&B Member since '03
03-08-2004, 06:00 PM
I crawled under my rig and sprayed it with Rustoleom High Heat BBQ paint.
It got pretty scratched up this weekend, but thanks to the left over contents in the orginal can, it's going to take me a hole minute to repair.
Cheap and Effective.
03-08-2004, 06:08 PM
I did some serious scuffing with 80 grit sandpaper first & they used the Line-X cleaner on it; they were spraying someone’s bed liner and didn’t even charge me for it ( they do all my detailing so they get enough $ from me) so I figured it was worth a try. I am just going to buy a cheap spray can of bed liner for touchups.
Rich
03-08-2004, 06:59 PM
Isn't this how that thing is supposed to look?
________________________
Black 2003 H2 - Just like most of yours, just possibly with less crap bolted on.
My job: http://www.HardOCP.com
This place sucks now, bye.
03-08-2004, 07:15 PM
FrgMstr,
You finally found another color to go with your all black H2 that looks gooooood  .
Thanks,
David
Black H2
Thanks,
David
Black 03 H2
Green 97.5 H1 Wagon
03-08-2004, 07:16 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by FrgMstr:
My job: http://www.HardOCP.com<HR></BLOCKQUOTE>
I like the look
FrgMstr, Do you by chance have a pic of your drivers side front floor mat. I had some of the husky's once but that lip gave me problems, just want to see the coverage and lip hight in an H2.
Did I see you looking for factory rim(s)?
Rich
03-08-2004, 07:54 PM
Line-x comes right off. A friend of mine had his rock rails sprayed with it and it all tore off in sections. It looks good though (for a while  )
03-10-2004, 06:15 PM
Mine have not ever bothered me....
03-10-2004, 06:17 PM
Different Angle
The back just for kicks
03-10-2004, 06:19 PM
And also, I checked into getting my rocker bars and brushguard done, and some other stuff and none of the Rhino or LineX guys suggested it if I actually used my truck off road.
If you are going for looks alone, they said that even then on a nonflat surface it would likely peel sooner or later.
03-10-2004, 07:30 PM
Thanks for the pics, I am going to pic up a set.
