Old 06-04-2013, 01:50 AM
ryaleon's Avatar
ryaleon ryaleon is offline
ryaleon is on a distinguished road
Default Manifold and Exhaust
So I have a broken manifold bolt, figured while I was in there changing it out I might as well swap the manifolds and all bolts.
Can anyone recommend a good set of headers that will work with the stock exhaust?
Will this work? http://www.ebay.com/itm/CHEVY-GMC-4-...0fb08a&vxp=mtr
Or this? http://www.ebay.com/itm/181152402419... 4.m1438.l2649
2008 Hummer H2 Lux Ed. Sedona Interior. XD Spys wrapped in 37x13.5 Toyo Mtsss.
Old 06-04-2013, 11:45 PM
jsbihn jsbihn is offline
Moderator
Default Re: Manifold and Exhaust
I am curious too.
I am also wondering if there are any real gains to this.
I know some of the cheaper headers at some point had cracked when it came to other cars but I would like to see how these would work.
Btw ryaleon, it looks like we have the same taste in cars.
I have a 2003 H2 and a 99 Corvette heavily modded with more to be modded :-)
(and a 2004 M3 which is probably getting sold)
Old 06-05-2013, 12:19 AM
ryaleon's Avatar
I have a 2003 H2 and a 99 Corvette heavily modded with more to be modded :-)(and a 2004 M3 which is probably getting sold)
I'm actually going to sell my C6 sometime soon.....but only because I want the C7!
Old 06-05-2013, 07:00 AM
LoJac963's Avatar
LoJac963 LoJac963 is offline
I've mentioned many times that OBX has been proven quite a few times. Although cheap they essentially copy the big name brands and put out virtually the same product. When I had my GTO the vette guys went nuts over OBX.
Compare the price of Kooks LT's and OBX LT's and its a no brainer. Send them to get ceramic coated inside and out and you've got a great set of headers.
As far as gains, you won't get much with shorties-long tubes is where its at. That however means reconfiguring your entire exhaust where the shorties will bolt right in place of the oem manifolds.
When I eventually swap mine out I'll go with OBX simply due to the price. Still haven't decided whether to go with shorties or LT's. Probably shorties just because I have no interest in changing the stock exhaust.
Old 06-05-2013, 01:36 PM
ryaleon's Avatar
Obx seem like the way to go then. I too have no intentions of changing the stock exhaust.
Old 06-05-2013, 01:50 PM
ryaleon's Avatar
I'm assuming that if the headers are compatible with an 07 they should be fine for 03-06 right?
