07-19-2013, 05:12 PM
High pitch whining noise, front right area
Had this problem for over a year now.. seems to go away during cold months. And is very noticeable during warmer seasons.
It's a very high pitched whiney, crackling noise that comes from the front right area of the cabin. At first thought you think it's the speaker, I've replaced the speaker, no change.
One odd ball thing is if I press the power button on the onstar module it will turn the noise off but then it starts right back up again, soooo annoying. I'm planning to rip apart the dash and disconnect the navi, onstar and then go from there.
I got a video of it.... anyone seen this before? I've been searching for answers for awhile now and had no luck
http://youtu.be/l5Btgn6cHuA
Yellow 04' H2
07-19-2013, 11:56 PM
Moderator
Re: High pitch whining noise, front right area
TECHNICAL
Bulletin No.: 07-08-46-002D
Date: July 29, 2009
Subject: Audio Whine Noise from Radio Speakers When Using OnStar(R) (Install Noise Suppression Filter)
Models:
2007-2010 GM Passenger Cars and Trucks (Including Saturn)
2007-2010 HUMMER H2, H3
2007-2009 Saab 9-7X
Equipped with OnStar(R) (RPO UE1)
Supercede:
This bulletin is being revised to update the Warranty Information. Please discard Corporate Bulletin Number 07-08-46-002C (Section 08 - Body and Accessories).
Condition
Some customers may comment on an audio whine coming from the radio speakers when using the OnStar(R) system. The amplitude and frequency of the whine will change with an increase or decrease in engine speed.
Cause
This condition may be caused by electrical noise on the OnStar(R) Vehicle Communication Interface Module (VCIM) battery feed wire being passed to the microphone output pins at the radio.
Correction
Technicians are to install a noise suppression filter, P/N 1224205, into the OnStar(R) battery voltage circuit, a few centimeters (inches) from the VCIM. The filter package has three attached wires - a single yellow wire at one end with a yellow wire and a black wire at the other. Install the single yellow wire side into the battery voltage circuit towards the VCIM. Install the remaining single yellow wire into the battery voltage circuit toward the fuse and the black wire to ground.
Important
The noise suppression filter is polarity sensitive. The filter is designed to be most effective when the end with the capacitor ground is connected towards the source of the electrical noise. Install the filter in this polarity first. If the noise level is still not satisfactory, try disconnecting the capacitor ground. In some cases, if the first installation does not correct the noise, try reversing the filter polarity (removing the filter, turning it end for end and then reinstalling it) and grounding the capacitor lead.
07-20-2013, 01:05 AM
Originally Posted by fyr145
TECHNICAL
Date: July 29, 2009
Models:
2007-2009 Saab 9-7X
Supercede:
Condition
Cause
Correction
Important
OMG!!!!!!!! YES!!!! THANK YOU!!!!
Yellow 04' H2
07-20-2013, 12:43 PM
Moderator
Fyr is quickly becoming the new guru....
guruerror might have to turn in his crown :-)
07-22-2013, 08:49 PM
Well I thought I was in the clear but I heard the noise again today....
I have the Onstar module completely disconnected but I did keep it mounted in the bay for looks.
I can't believe this.... what else could it be??!
Yellow 04' H2
