Old 07-20-2013, 06:11 AM
MrIgor MrIgor is offline
MrIgor is on a distinguished road
Default tricky no start problem..
Today I finished installing new transmission, the engine cranks BUT ONLY starts for a sec if i spray starter fluid into throttle body (quickstart) and dies right away. Looks like I have no fuel BUT The most confusing thing is in the fuel rails there is fuel if i press the release nipple.
It started before like clock work, no problems ever before I replaced transmission. it cant be a wiring thing, because I have spark, and NO check engine codes.
How can it be that I have fuel in the rails, and spark and wont start???
Old 07-20-2013, 12:41 PM
jsbihn jsbihn is offline
Moderator
Default Re: tricky no start problem..
Is the trans in the park gear?
Old 07-20-2013, 04:05 PM
yes otherwise it wouldnt let me crank
Old 07-20-2013, 04:36 PM
I noticed my PCM fuse was blown, installed new one.. but no changes.
Old 07-20-2013, 08:38 PM
update: i just checked i have constant 57 psi. and i have spark. But wont start??? if i spray starter fluid into TB it runs for a second or two then dies.
What am i missing?
Old 07-20-2013, 11:46 PM
it seems the PCM is not sending signal to the injectors, but the injectors do have power.
Old 07-31-2013, 06:52 PM
theft system disables injector pulse. are you using a new key?
