Old 07-25-2013, 03:02 AM
jsbihn jsbihn is offline
Moderator
Default engine revving in cycles
Hey all,
I think I know the answer to this one , but because the H2 could possibly be different animal to what I an experienced with I wanted to ask your opinion.
It seems that when I get into my rig and start her up the idle cycles in the rpms.
800-1000-800-1000-800-1000
Shortly after it is idling normal.
No codes when I scan then using the 327 scanner tool.
So I am wondering what you think....
(p.s. just started happening a few days ago)
Old 07-27-2013, 02:03 PM
Moderator
Default Re: engine revving in cycles
anyone????
Old 07-27-2013, 10:28 PM
Moderator
BUMP
Old 07-31-2013, 12:27 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
What year of H2 do you have? If you have drive by wire throttle body it may just be a dirty throttle body bore and plate. Could also be leaking intake gaskets seeing its a dry intake it will suck in unmetered air(vacuum leak) until it warms up enough to seal the leak
1998 Chev Z71
2007 Chev Trailblazer SS
Old 07-31-2013, 11:24 AM
Moderator
Sweet Humtech is here!!
Ok, this is my info
2003 H2 with about 125,000 on the clock.
The cycles started a while back but no codes are shown
I have found out that it isnt a warm or cold engine issue now.
Basically I can come out the the truck, jump in, start it up, sometimes it will rev in cycles, sometimes it doesnt. One good push on the throttle and the cycling goes away.
I have done some research and believe that you are probably right about the throttle body needing cleaning.
Is there a specific chemical/ cleaner that you would suggest for this?
THANKS AGAIN!!
