Old 09-22-2013, 01:16 AM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Default AC Delco battery lasted 8+ years
My stock AC Delco battery in my 05 is starting to crank a little slower so I decided to swap it before winter. Actually it was still going which is excellent for a battery so I wanted another AC Delco. Come to find out AC Delco's new group 79 battery is only 840CCA not the 880 that was stock. After looking around I found a Bosch from PepBoys for $150 and it's the full 880CCA. Probably wouldn't have made a big difference but 40 amps is a lot.
Old 09-22-2013, 01:34 AM
jsbihn jsbihn is offline
Moderator
Default Re: AC Delco battery lasted 8+ years
Yes, 40 amps is alot when you are dealing with an amp pig like our rigs.
Have you tried NAPA. Personally I am big on their warranty and batteries (much better then the Optima batteries I used to use.)
'03 H2 (name: Big Gulp)
