Old 09-30-2013, 11:48 AM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
Default Replace liftgate fuse
Getting this annoying replace liftgate fuse display and dinging on the DIC. Liftgate fuse is fine. Infact checked all fuses and they are all fine. Replaced the liftgate fuse just for drills. Liftgate locks and opens fine with remote key. Any ideas?
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 09-30-2013, 07:08 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Replace liftgate fuse
If a short to ground is present on the liftgate lock relay control circuit, the liftgate lock relay will be energized and the liftgate lock actuator will be held in the lock position and will not unlock.
If an open condition is present on the liftgate lock relay control circuit, the liftgate will unlock but not lock.
The BCM will send a class 2 message to the driver information center (DIC) indicating that a fault has been detected and the DIC will display REPLACE LIFTGATE FUSE.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 09-30-2013, 07:09 PM
HUMTECH's Avatar
An open ECC fuse
An open or short to ground in the liftgate lock relay battery positive voltage circuit
A faulty liftgate lock relay
An open or short to ground in the liftgate lock relay control circuit
A short to ground in the liftgate lock actuator lock control circuit will open the electronic climate control (ECC) with a lock command
A faulty BCM
1998 Chev Z71
