Old 12-09-2013, 12:24 AM
Bshosten Bshosten is offline
Bshosten is on a distinguished road
Default H2 rear shock absorber socket size question
Just noticed my rear shocks are leaking fluid, so time to replace and upgrade! Was hoping someone could tell me what size socket the shock mount bolts/nut takes. Put a 21mm on it be seems like a lot of play. Other than that looks fairly simple on the rear with no struts. Any advice appreciated as to the job.
Old 12-09-2013, 01:42 AM
Easy Ed Easy Ed is offline
Default Re: H2 rear shock absorber socket size question
On a 2003 the lower socket size is in the third post from the bottom here http://www.elcovaforums.com/forums/s...t=42682&page=2
Old 12-09-2013, 01:45 AM
Thank you!! Did read that post but missed the 21mm info.
Old 12-09-2013, 02:01 AM
Good luck, Ed
