Old 12-20-2013, 02:43 PM
jsbihn jsbihn is offline
Moderator
Default All The Lights
Hey all,
I am starting to think I want to replace my lights with LEDs.
When I say my lights, I mean all of them.
Inside/Outside/Dash/Running....etc (you get the point, all of them)
So What I need to do is find out all the light codes or types so I can match them up.
I dont want to just up and buy some lights from ebay that says it is made for the H2. I want to make sure all the lights are the same temp/or degree of white.
Also, I would like to replace the fog lights with something more LED and useful. Currently I have the stock ones behind a cloudy plastic lens, and I wanted to know if anyone had any ideas on how to fix or replace with a better setup.
Lastly the roof marker lights (the center ones) are starting to go out. I have gotten up there to pull the bulb to try to replace them only to find it near impossible to pop off the cover and now of course I dont know the bulb to swap out for LED.
Anyone have a list off all the bulbs we have so I can try to get the match in LED form.
'03 H2 (name: Big Gulp)
Old 12-20-2013, 04:45 PM
fyr145's Avatar
fyr145 fyr145 is offline
Moderator
Default Re: All The Lights
This has come up so many times..............
The man to see is LoJac963. Hes converted all of his lights to LED's. I believe that hes even made a complete thread on this very topic. Not sure which site its on but hes definitely the person to talk to about this.
Old 12-20-2013, 07:05 PM
Moderator
Thanks Fyr,
I went "searching" and didnt really see anything on here.
And then I tried to look through CHO but it appears the site is down or something.
LJ....
Can you direct me to your write up?
(p.s. I am searching the archeives too)
Old 12-20-2013, 11:21 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Look through my build thread here:
http://www.clubhummeroffroad.com/for...-s-Deuce-Build
I'll answer any questions you have. Unfortunately I don't have many pics on the LED install throughout the dash and controls.
Old 12-21-2013, 02:11 AM
Moderator
LJ,
Thanks.
Actually I looked on both Elcova and CHO through your build threads..... didnt see anything in there about what lights to get.
Basically I am looking for a running down on all the lights our rigs have so I can find an LED direct replacement.
(ie. lets say the console light or the over head light or even the outside lights all have a part number you can look up in a book.... I am trying to find 1) the part numbers and 2) where is a good place for me to get all of them at in LED form)
Old 12-22-2013, 12:20 AM
LoJac963's Avatar
If you're talking about the dash and instrument lights I have never seen an actual part number. They would be included in say the "cluster" part number.
For ordering LEDs, you basically need to find one seller and buy everything from them. That way you know the LED's are all the same-that's what I did when I did all my projects.
Old 12-23-2013, 06:59 PM
Port it over here. When I click that link I get:
Fatal error: Cannot redeclare fi() (previously declared in /home/clubhumm/public_html/forums/showthread.php(1) : eval()'d code(2) : eval()'d code(1) : eval()'d code:1) in /home/clubhumm/public_html/forums/global.php(1) : eval()'d code(2) : eval()'d code(1) : eval()'d code on line 1
Maybe because they still hate me?
Old 12-23-2013, 07:40 PM
LoJac963's Avatar
They're working on the site, nothing comes up for me either. I have a build thread on hummer 4x4 offroad.com also
