Old 12-31-2013, 06:28 PM
Ken Bowers Ken Bowers is offline
Ken Bowers is an unknown quantity at this point
Default How to remove ceiling panels
I have an orange H2 (2003). There is a hum coming from the doohicky above my head which I believe is a speaker for the OnStar. (The specs say it is a fan).
When I took the cover off, the doohicky shifted out of view.
If I have to remove the ceiling panel to get at the doohicky, how do I do this? Must I make a cut in the panel?
Is there a fuse I can remove to get this doohicky to shut up?
Old 12-31-2013, 06:45 PM
smileynialley's Avatar
smileynialley smileynialley is offline
smileynialley is on a distinguished road
Default Re: How to remove ceiling panels
I have the same issue.
The doohicky you're referring to is a sensor for the air conditioning I believe. apparently it's common for them to make this noise when they are worn out. You need to replace the sensor thing but I'll be damned if I know where to find one or how to take off the headlining.
Old 12-31-2013, 08:05 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
If you remove the a-pillar trim panel(down the front left side of windshield inside) you can just pull headliner down enough to get hand in there(its tight) then you can reach it. smiley you are correct it is the inside air temp sensor. Other term for it is aspirator. If you remove it your auto temp controls will not work. Not a very expensive part from dealer and yes it does have a fan in it, that's what is causing the noise.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 12-31-2013, 09:24 PM
Is there a fuse which will stop the fan?
Old 01-01-2014, 02:01 AM
HUMTECH's Avatar
No, works through hvac control module. Only thing you could do is unplug it at sensor.
1998 Chev Z71
Old 01-03-2014, 06:43 PM
So far, I see no way to remove the paneling. It has a speaker and a hand hold.
Another problem: my TC and ABS warning lights come on for no apparent reason. (I think the battery is low).
Old 01-03-2014, 08:29 PM
HUMTECH's Avatar
Top and bottom of handle has two pop out retainers, use a small flat blade to release them to the full out position and the handle will pull off then the trim panel can be pulled off it is held in place with clips.
1998 Chev Z71
Old 01-03-2014, 08:31 PM
HUMTECH's Avatar
From the manual
Using a suitable flat bladed tool, release the retaining tabs and remove the assist handle.
 2. Rotate the windshield garnish molding inboard to disengage the retaining tab, then rotate rearward to remove from vehicle.
 3. Disconnect the speaker connector.
 4. Remove the windshield garnish molding from the vehicle.
1998 Chev Z71
