Old 01-13-2014, 07:26 PM
jsbihn jsbihn is offline
Moderator
Default UGH! What is up with this truck! (wipers)
Hey all,
Soooo here is the latest in a ever growing (faster than I can fix it) list of things going on with my Rig.
Yesterday I was driving when the front wipers came on. It wasnt raining (though it rained a day or two before) and this wiper craziness was out of the blue... meaning I had driven then turned the vehicle off then drove again and nothing happened until.... When they came on, they came on for a couple of swipes and then stopped - mid way through the wipe. So I left it there figuring it would dry out if it needed too or would reset itself. This morning I go out and sure enough they are stuck. The switch wont work... nothing, just as they were yesterday. I check all fuses and everything is good there.
I manually push the wipers down because I couldnt drive with them on the windshield obstructing my view. Suddenly about a minute later they wipe on their own and get stuck again.
That was it.
Now I have broken wipers, broken wiper fluid pump (front and back), and I am wondering what will happen next
any help?
I am not looking to buy new parts if there is an issue that i can fix, but if it needs the new parts..... well I am buy them
'03 H2 (name: Big Gulp)
Old 01-14-2014, 06:46 PM
Moderator
Default Re: UGH! What is up with this truck! (wipers)
Ok all,
Here is the latest.
This morning I turn on the wipers and still nothing.
But I can hear something move or make a sound when the wipers are turned on. So I grab one of the arms and give a little tug. The wipers moved with no issue on their own. A full sweep.
Then they returned to the start position and that was it. The next attempt to the sweep gave me the same little movement and sound from the motor.
Everytime I would pull on the arm the wipers would move, but once they returned they couldnt.
So it seems like the motor is ok, but maybe it is slipping on the arm??
Any help?
Old 01-14-2014, 07:45 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Remove the cowl trim to get to the motor. Turn on the wipers and tap the motor housing with a rubber mallet lightly, if the wipers swipe you need a motor.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 01-14-2014, 10:09 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Also I thought I read a few threads of the circuit boards going bad in the motors because they aren't sealed or something? I could be wrong....
Old 01-14-2014, 11:50 PM
Easy Ed Easy Ed is offline
Yup....
http://www.elcovaforums.com/forums/s...ad.php?t=44607
Old 01-15-2014, 02:58 AM
Moderator
Originally Posted by Easy Ed
Yeah I read a while back that you should seal them too.
I think I heard that between Ed and Guru
Of course, my laziness is going to now probably cost me 200 bucks
Old 01-15-2014, 02:56 AM
Moderator
Ok, and if they dont?
