02-11-2014, 11:13 PM
power folding mirrors?
i have 03 h2 how to check if i have power folding mirrors? any different on actual buttons?
02-12-2014, 12:47 AM
Re: power folding mirrors?
The large button that you use to move the mirrors, you push in the middle and both are supposed to fold in at the same time.
I wish you luck cause they seem to die after a while and stop working altogether.
~Richard
02-12-2014, 05:50 AM
where all of them power folding? or some special package or addon?
if i hold the big button, nothing happens
02-12-2014, 10:27 AM
There's the big square button where you can push to adjust each mirror. Directly above that is a small rocker switch where you push it either left or right to adjust each mirror. Put that small rocker switch in the middle and an amber LED should light the center of the BIG square switch. Then you push the big square switch to the right to fold the mirrors in or left to fold them out.
Kind of confusing, hope it helps.
02-12-2014, 12:20 PM
Moderator
A+
'03 H2 (name: Big Gulp)
02-12-2014, 05:05 PM
and if that does not work? how to check if my truck came with the folding option? or all of them did?
02-12-2014, 06:13 PM
all of them did, and basically they stop working after a few years
02-12-2014, 10:18 PM
any DIY on how to troubleshot them?
02-12-2014, 11:49 PM
02-13-2014, 04:25 AM
Ok I was told wrong all theses years sorry if I lead you a stray,,, now I want to run out and try them again to see if they will or will not work. ~Richard
