02-15-2014, 09:30 PM
Lower Ball Joint Replacement
Kind of a mental note.
In progress of doing the upper and lower ball joints at the moment.
Upper Ball joints - no problem
Lower Ball Joints - Needed a 50 tonne hydraulic press to remove them.
They have been a bit slack for the last 5,000 miles or so. But not bad wear and tear for 130,000 miles really
02-16-2014, 04:11 PM
Re: Lower Ball Joint Replacement
I used a 2 pound hammer and some PB Blaster for the lower. Then an OTC ball joint kit to press in the new ones. Took about 8 hours to do the lower and uppers on both sides, plus change the wheel bearing assemblies.
03 H2 Pewter W/Lux, with 05 Navigation Radio and XM added. (Sold)
07 H3 Slate Blue W/Lux, Off-Road, NAV, Sunroof, XM, Tow, Auto (Sold)
08 H2 White W/Lux, NAV, Air Sup.
02-17-2014, 05:54 PM
I need to do the same thing; hubs and joints. I own a 20 ton shop press so that will help. Anything else recommended to change while doing these changes? I assume brakes wouldn't hurt.
02-17-2014, 10:27 PM
Good time to upgrade the tie rods to heavy duty ones. Especially if you off road or have bigger tires.
Hybrid Mode
