Old 02-21-2014, 10:19 PM
jsbihn jsbihn is offline
Moderator
Default Cowl removal - assistance
Hey all,
I know this has been discussed on here before, but after searching through the site I have yet to find detailed instructions.
I am looking for detailed instructions on how to remove and replace the fake air scoops/intakes and cowl on my rig.
I think I read there is a trick to it and also that removal has to be careful since you could break off pieces.
So I figured I would brave the "its so simple, youre stupid" comments to make sure I am doing it right since this is my daily and i can afford down time or more things breaking as I am trying to fix things that broke now
Thanks all.
'03 H2 (name: Big Gulp)
Old 02-22-2014, 12:36 AM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Default Re: Cowl removal - assistance
They basically just pop off. They are held in with standard clips. I've had mine off a bunch of times and this last time I did break one of the small alignment posts. It doesn't do anything honestly since all the clips are intact. If you have any of those plastic pry bars, the non scratching ones you can slowly use one of those.
Old 02-22-2014, 01:49 AM
Moderator
So all the piece are just held in with pressure clips? And some light pressure and a little finess and out the three (?) pieces should come out?
Old 02-22-2014, 01:38 PM
fyr145's Avatar
fyr145 fyr145 is offline
Moderator
They lift/pop straight up. There are 4 clips to each "intake". You'll see how they look once you get the first one off.
Old 02-22-2014, 03:10 PM
Easy Ed Easy Ed is offline
Yup, part way down the page http://www.elcovaforums.com/forums/s...ad.php?t=38537
