Old 03-10-2014, 04:25 PM
jmudler jmudler is offline
jmudler is on a distinguished road
Default Control arms - Ball joints
I have a question about upper control arms (UCA). I noticed two different models from Moog.
CK620054
Front Upper; Incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces; Standard bushing
CK620053
Front Upper; Incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces; Incl. offset bushings offering an additional 2 degrees of camber change
1) Would CK620053 be a better option if I do leveling keys to aid in camber/alignment?
2) I plan on using my 20 ton shop press for the ball joints, and when I remove the lower control arms to replace the joints and bushings do I need to worry about the torsion bars? In other words do I need to decompress the torsion bars via the torsion keys?
Old 03-13-2014, 12:40 AM
H2ummer H2ummer is offline
H2ummer is an unknown quantity at this point
Default Re: Control arms - Ball joints
CK620054
CK620053
I can't say for sure adding 2 degree's is necessary just for cranking your Torsion bars, but thoughts are they are not needed.
I can say for sure, you don't need to remove the upper and lower control arms to replace the ball joints. A lot of work involved in doing that. I replaced my ball joints (upper and lower) with the control arms in place. I used a Ball Joint removal/insertion tool kit, like this http://www.harborfreight.com/ball-jo...l#.UyDx1NfD9Bk The lower ball joint needed a bit more persuasion so some PB Blaster and a hammer finished up the removal. The kit made it easy to put the new Ball Joints in.
03 H2 Pewter W/Lux, with 05 Navigation Radio and XM added. (Sold)
07 H3 Slate Blue W/Lux, Off-Road, NAV, Sunroof, XM, Tow, Auto (Sold)
08 H2 White W/Lux, NAV, Air Sup.
