Old 04-01-2014, 04:24 PM
Egan's Avatar
Egan Egan is offline
Egan is on a distinguished road
Default Windshield Wiper Gremlins
So, we're finally getting some rain in Kalifornia and I start having wiper issues with my 05 H2. Every once in a while the wiper would just stop working when it was on intermittent. I have a short commute so I didn't really notice it, and changing the the delay up or down a notch resolved the immediate issue.
However, this morning I had a new, weird problem. About 4 miles into my 12 mile commute, with the wipers on the slowest intermittent setting, the washer fluid sprayer came on and did not stop. The only way I could get it to stop spraying was to push the sprayer button forward and hold it there (for the next 8 miles). I even pulled over and shut off the engine for a minute without success. I kept letting off the switch every mile or so to see if it fixed itself and it wasn't until I pulled into the parking garage at work that it went back to normal operation.
I was planning to pull the washer pump fuse (assuming it's a separate fuse from the wiper motor) but looks like I won't have to.
Any idea what caused this? I'd rather replace the part now than have this happen again in the future. Any idea what part needs replacing?
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Kryptonite Swaybar End Links
Traxda Keys
Traxda Rear Coil Spacers
Bilstein Shocks
TruCool Tranny Cooler
Corvette Servo
Gobi Ranger Roof Rack
Gobi Bed Rack
Pioneer AVIC-Z110BT: Nav, Bluetooth, iPOD, Backup Camera
Valentine 1 w/ Blend Mount
ATX Artillery 17x9 Teflon
Toyo Open Country MT 37x13.5x17
Old 04-01-2014, 10:26 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Default Re: Windshield Wiper Gremlins
I've read of multiple people having these issues. The wiper motor is not correctly sealed and can get water inside the housing. Once inside the corrodes the boards and causes all sorts of electrical issues. Some have taken the motor housing apart, cleaned everything up, assembled, and sealed it all shut and ran without issue.
Old 04-01-2014, 10:59 PM
Easy Ed Easy Ed is offline
6th post down here http://www.elcovaforums.com/forums/s...ad.php?t=29583
4th post down to get to it http://www.elcovaforums.com/forums/s...ad.php?t=38537
Hope it helps, Ed
Old 04-02-2014, 01:50 PM
PaHumBug's Avatar
PaHumBug PaHumBug is offline
I vote we make a sticky about this issue. Someone asks about it every couple months.
Old 04-03-2014, 05:40 PM
Hellz Hellz is offline
i had a issue with my wiper motor about a year ago.
wiper worked on and off. made very loud whining noise. no issues with it dumping fluid.
so ya, it basically water leaking into the motor and causing issues. people have pulled the motor and cleaned up the contacts and sealed it with silicon.
for my issues, it didnt seem like that would be a fix for me, so i opted to buy one off of ebay. dont remember the price, but it was a little over $100 for a new motor. was very simple and easy to remove the old one and install the new one. it took me about 1.5 hours, but that was due to me working on it outside in the middle of winter in minnesota. in warm weather or a garage, i would give this about 30 mins.
Old 04-04-2014, 01:33 PM
PaHumBug's Avatar
Yeah it's an easy fix, the hardest parts is getting the damn cowl on and off.
Old 04-04-2014, 02:28 PM
ya without breaking any of the tabs.
not the plastic grommets that hold it on, but the tabs where the grammets go through.
i know i broke one when i did mine.
cold + plastic = not good
Old 04-06-2014, 01:36 PM
Egan's Avatar
Thanks for all of the helpful info. I'm going to tackle this today. Fortunately it's supposed to be 80F.
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Traxda Keys
Bilstein Shocks
Corvette Servo
Gobi Bed Rack
