Old 07-18-2014, 12:54 AM
TheH2 TheH2 is offline
TheH2 is on a distinguished road
Default Will this wheel/tire setup work on Stock setup?
I have a 2003 Hummer H2 currently with KMC Backseat 22" and I believe it is a 10" or 11" wide on 325/50 Nitto Terra Grappler on stock suspension w/air ride. I believe the offset is 8x170. I have a tuner that I used to adjust the odometer
I am looking at a new set of wheels and tires and want to make sure these will fit with the stock suspension. I am looking at"
XD Series Rockstar II in a 22x9.5 with a 12mm offset
or
Fuel Octane with the following size/offset options
22x10 1
22x10 -12
22x10 1
22x10 13
22x10 1
22x10 -12
22x10 13
22x10 1
22x10 -12
22x10 13
22x10 1
22x10 -12
22x10 13
22x14 -64
22x14 -76
22x14 -76
22x14 -64
22x14 -76
I want to get the Toyo Open Country M/T 35/12.5/22, or possibly 37/35/22 if they would fit. I like the wide looking tire look. Ideally I'd like the 22x14 so that the tires don't bulge from the rim. Can you guys please advise which would work best as far as size and offset. I am leaning more towards the Fuel Octane. AGAIN I AM ON STOCK SUSPENSION WITH AIR RIDE
Old 07-30-2014, 03:55 AM
twenty2's Avatar
twenty2 twenty2 is offline
Default Re: Will this wheel/tire setup work on Stock setup?
you can go with 20x10's with 325x60x20 or 35x12.5x20's without any rubbing at all. 35's are safe to go with. I'm sure the 37's without a lift would rub at full tilt
Old 07-30-2014, 06:03 AM
LoJac963's Avatar
LoJac963 LoJac963 is offline
I actually just installed new wheels today from TireRack. They are 17x9 with a 4.25 backspace which equates to a -19 offset. I wanted them pushed out because I have the extended offroad flares. With that offset they are perfectly flush with the flares. Plus the wide stance looks awesome.
Check my build thread on here for pics.
35's are the stock size and 37's should fit no problem, some fit better on some rigs than others. My stock 35's rubbed on the passenger sway bar. However with the offset I have they are pushed further away from the side of the wheel well. Also the tires I bought were almost 2" taller than the stock BFG's even though they were both 315's.
Keep that in mind, every tire is going to have a different height. TireRack usually puts the overall height in the specs tab of their tires.
Old 10-28-2014, 02:15 PM
baldfox's Avatar
baldfox baldfox is offline
baldfox is on a distinguished road
Hey, how did you get on with this ? I was looking at those rockstar wheels myself, (22*9.5s). I have a standard SUV, so interested if i'd need to lift/level it to get them under there with no probs...
Am flexible on the tyre!
Baldfox
2009 H2 SUV, Trucklite LEDs, Airdoc
