Old 07-24-2014, 02:30 PM
dna dna is offline
dna is off the scale
Default Weird brake wear
I have an 03 H2 with 123k miles, which I've owned since new. I just did the very first brake job on it. The fronts had 5% left (just before the warning tab) but the backs had 60% left.
Is this normal? Not only getting so many miles on the first set of pads but the very uneven wear between the front and back pads?
Old 08-20-2014, 06:22 PM
GLBLWARMR's Avatar
Default Re: Weird brake wear
This is normal across all vehicles. Most cars and trucks, my F350 included, have larger front calipers 4-6 piston where the rear are single and maybe double piston on stock setups. Most of your stopping power is applied via the front brakes, thus causing those pads to wear faster. I average 2 front pad changes to 1 rear pad change.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
