Old 08-04-2014, 06:08 AM
Konowa's Avatar
Konowa Konowa is offline
Konowa is on a distinguished road
Default So slow in here/damn vent on defrost issue
After disconnecting the battery to do a bit of welding for the header install my vents keep defaulting to defrost. Got hot and cold left and right but cant get it off defrost. I watched the servo do its calibration and noticed it only goes halfway through its range before going full defrost vent. Weak servo maybe? My crappy odbII reader doesn't show any codes. Does it require a high end unit to get to those codes?
Old 08-04-2014, 06:17 AM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Default Re: So slow in here/damn vent on defrost issue
Typically most lower end readers won't pick up on everything. I think most auto stores will scan it for free and give you a print out of the codes.
Old 08-12-2014, 05:08 PM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
HVAC Servos won't throw a code. Try to pull the battery or fuse and recalibrate and if that doesn't work it looks like you'll have to replace it. They are known for going bad.
