Old 11-20-2014, 12:14 AM
pdxrealtor's Avatar
Default Shocks - Not happy with Rancho and want to swap
So I got the Rancho adjustable shocks at 50k. Never really did like them but they've softened up quite a bit. I'm at 72k. I'd like to replace them with either OEM or another brand that is just as stiff.
What do you guys suggest?
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 11-20-2014, 02:30 AM
citiboy's Avatar
citiboy citiboy is offline
citiboy is on a distinguished road
Default Re: Shocks - Not happy with Rancho and want to swap
I replaced my oem with bilstein 5100 on all corners. It's perfect for my set-up with the cranked keys, the ride gets harsher with oem shocks. With the bilstein, it almost returned to normal ride.
2008 Hummer H2 Luxury Edition
Toyo MT 38x13.50x18 on Rockstar. Green keys. 2" rear spacers. 1" bodylift. Cognito UCA, steering bracket, front stab links. Bilstein 5100 shocks & steering stab. Moog inner/outer TR, pitman, idler arm & bracket with remote zerk. E&G Classics fender flares. ARP 434-1301 ex. man. stud kit. Airaid perf. air filter. Crown brake lines. Warn PowerPlant HD. Rubberduck UCP. Gobi Ranger roof rack. DDM Tuning 55W HID Hi/Lo headlights. Hella fogs. Evans waterless coolant.
Old 11-20-2014, 02:38 AM
pdxrealtor's Avatar
THx. What do you mean by 'ride gets harsher with OEM shocks'? Are you referring to over time as the OEM shocks wear out the ride gets harsher? OR??
Bilstein.... that was the other brand I contemplated when I got the Ranchos.
I know I was happy with the OEMs, and would just like to get that back via OEM or Bilsteins. Ranchos aren't the one.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 11-20-2014, 04:43 AM
pdxrealtor's Avatar
http://www.4wheelparts.com/Lift-Kits...FY9cfgod7FIATQ
Not a bad price on the billsteins... cheaper than my Ranchos were..... If I remember right the billsteins were more expensive back when I got my Ranchos.....
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 11-20-2014, 08:06 AM
pdxrealtor's Avatar
So after some searching I'm not sure if the Bilstein 5100s are good to use for a stock height truck.
Can anyone confirm the 5100s are the shocks for stock height? And they are stiffer than the Rancho 9000 on the stiffest setting?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 11-20-2014, 08:18 AM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Quite a few are running them on stock height rigs without issue. It's the route I'm going to go when I start going through my front and rear suspension and replacing stuff. However I do plan on new keys and spacers for a small 2-3" lift.
Old 11-20-2014, 01:50 PM
citiboy's Avatar
What i mean is, when i replaced the original tb keys with gm green keys and cranked 2", the ride got harsher with oem shocks. So i replaced them with bilstein 5100 and immediately notice the softer ride. I think the Bilstein are softer than the oem shocks.
I bought it from this site.
http://www.eshocks.com/bil_veh.asp?M...=All&SubChar=Q
Old 11-20-2014, 07:50 PM
pdxrealtor's Avatar
^^ ah... got ya! Thx for clarifying.
So my next question is, just how much softer are the 5100s on stock ride height compared to a good set of OEMs?
I don't like body roll. Yes, I know it's a Hummer, but the OEM shocks never gave it to me. They also never let the truck bounce around front to back while going over a curb or bump in the road (think uncle buck).
As it is now with the Ranchos on stiff I'm having to reduce speed while going around the same corners more than I did with the OEM shocks.
I will check out eshocks. Any good places to buy OEM shocks besides GM Parts Direct?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 11-20-2014, 09:19 PM
citiboy's Avatar
If i were to put back my suspension to the original height, i would install 5100s up front and keep the oem at the rear. I find that the rear of my 2 with 5100s were a little softer and bouncier. I cannot put back the rear oem shocks 'coz i've installed 2" coil spacers and the 5100s were longer than the oem's.
Old 11-20-2014, 10:08 PM
pdxrealtor's Avatar
I just called Rancho about their warranty. They tell me they tightened up their manufacturing process and the shocks should not be as loose as they are after 20k road miles.
They are sending me all four new shocks. We'll see if they differ any.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
