11-26-2014, 12:22 AM
Oil Pressure Sensor
does anyone know if any special tools are needed to change the oil pressure sensor sending unit that is located behind the manifold?
I've read conflicting info.... mine is all of a sudden making the gauge go up and down, setting off the oil pressure low warning in the DIC.... which is accompanied by a ding ding ding. Gets very annoying!!
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
11-26-2014, 01:40 AM
Re: Oil Pressure Sensor
You need J41712 tool.
http://www.autozone.com/repairinfo/r...96b43f8025eccb
Scroll down to 6.0L engine.
Here's the actual tool http://www.ebay.com/itm/KENT-MOORE-O..._Tools&vxp=mtr
You can also use 1 1/16 deep socket.
Goodluck
2008 Hummer H2 Luxury Edition
Toyo MT 38x13.50x18 on Rockstar. Green keys. 2" rear spacers. 1" bodylift. Cognito UCA, steering bracket, front stab links. Bilstein 5100 shocks & steering stab. Moog inner/outer TR, pitman, idler arm & bracket with remote zerk. E&G Classics fender flares. ARP 434-1301 ex. man. stud kit. Airaid perf. air filter. Crown brake lines. Warn PowerPlant HD. Rubberduck UCP. Gobi Ranger roof rack. DDM Tuning 55W HID Hi/Lo headlights. Hella fogs. Evans waterless coolant.
11-26-2014, 02:05 AM
Thanks!
I wish autozone would have pointed that out when I talked to them.
I'm going to pick up a 1 1/16th socket from Autozone when I grab the sensor tomorrow. Fun stuff.....
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
11-26-2014, 02:46 AM
Make sure you check the fit of the new sensor to the socket while you're at the store.
11-26-2014, 04:21 AM
Thanks for the tip..... I will certainly do so!
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
11-28-2014, 05:24 AM
1 1/16" deep socket worked fine.
Used a 1/2" swivel on what was probably a 4" extension for a total of about 6".
It's a bit tight, but once you find it and get your method for reaching it's a pretty easy swap.
Thanks for the info citiboy.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
11-28-2014, 03:27 PM
You're welcome buddy...glad it worked out for 'ya. Keep the mods coming.
