Old 01-05-2015, 10:30 PM
jsbihn jsbihn is offline
Moderator
Default Need info about 3 inch front key and 3 inch rear spacer level lift
Hey all,
I am buying a torsion key and rear spring spacer level lift kit.
I have been told by the manufacturer that to install this I will need taller/longer rear shocks. I am curious if this is true, or for right now can the shocks I have now work? And if/when I get the rear shocks that are longer length, which ones should I get or where should I get them?
I have heard that you do need them, and you dont but they will be extended to the max.....? So of course I am curious.... If I can get away with the springs I have now working that would be great
I currently have a 2003 with air ride, which is going to have the spring conversion swapped when I do the lift.
Any comments would be appreciated
'03 H2 (name: Big Gulp)
