Old 02-17-2015, 06:01 PM
accely's Avatar
accely accely is offline
accely is on a distinguished road
Default FS: 2004 H2 SUV, Lots of upgrades
Hi all, putting my 2004 H2 SUV (Yellow) out there for sale, this is one amazing H2 with ALOT of upgrades and fixes, you'd be hard pressed to find a similar H2 at this price with everything already replaced and maintained properly. With this H2 you have 100% transparency knowing what has been done to it and you dont have the typical worry that comes with buying a used H2 in that you KNOW you would normally have to make alot of repairs and upgrades, but not with this H2, it's already done for you and neatly documented over the time I've owned. This H2 is in mechanically great condition and interior/exterior is good condition, needs some minor touch ups if desired, but nothing major or that hinders performance or capability.
Book value for private party is around $18k and in good condition. I've got about $10k put into it fixing it up and adding upgrades.
My asking price is 20k
Highlights:
123k Miles, excellent mechanical shape
Runs amazing, almost all major components have been upgraded/replaced, see list
All maintenance done as suggested and oil changes performed routinely
I expect this thing to run for along time now after what I've had done to it.
Over $10,000 in upgrades and fixes
Suspension upgrades support 37" tires and higher
Pictures:
http://s556.photobucket.com/user/acc...2%20for%20sale
Done @ 100,000 Miles:
Canister vent solenoid replaced
Brake fluid flush
Trans fluid flush
Front Differential fluid flush
Rear differential fluid flush
Transfer Case service w/ fluid flush
Fuel system cleaner w/ flush
Cooling system flush
Power steering flush
Spark plugs & ignition wires replaced
Idler Arm OEM
Both front axle seals replaced
Done @ 117,000 miles, Summer 2013
37" Toyo M/T Open Country tires
Cognito UCA kit
Bilstein 5100 shocks
Kryptonite HD Sway Bar End Links
Traxda Lift and Level Kit (Avg lift 2.0-3.0"Front & 1.25"Rear)
Moog Tie Rod Out-ES3609
Moog Tie Rod In-ES3488
NAPA pitman arm
Powerstop brakes and rotors (front)
AFE Cold Air Intake - Magnum Force Stage 2
Replacement stock exhaust (40k miles on the new one, replaced the original 117k mileage exhaust)
Superchips Cortex Performance Tuner 2950
Done @ 121,500, Fall 2014
Powerstop brakes and rotors (rear)
35" Nitto Terra Grappler A/T tires replaced Toyos
17" Rockstar XD Rims (brand new model)
Done @ 122,500, Jan 2015
New AutoZone Gold Standard battery w/ 3 yr warranty
48 point inspection done at Hummer dealership (noted airbag sensors) everything else is good to go
Misc:
Viper remote start system, LED key fob, 2-way up to 1 mile.
All Weather 3D Rubber mats
Installed Black texture door handles
Black H2 logos
Line-x'd Brush guard, tail lights, fenders, bumpers, grill, skidplate
Replaced dash modules (4x4,dome lighting, rear wiper)
Rockford Fosgate door speakers
Clarion CC510 Reverse camera w/ frame mount
Clarion NX501 Navigation system with remote
50" 300W 30000 Lumen LED lightbar on roof
2x 4" LED Work lights behind the lower grill
Replaced rear dome light housing
White LED interior light upgrade
HID headlights with new housings
LED front turn signals
LED rear taillights
LED bulbs for existing fog light housings
Known issues:
2x Front air bag sensors needed replaced (est. $250)
left rear panel has dent w/ minor paint chip and plastic roof panel is cracked by the roof light. The roof plastic peice just needs replaced but I could never find it. The dent would probably require a body shop (see picture of H2 from the rear)
small rust spot below driver side (not on door, it's on the body below the door)
small rust/paint chip on the rear left and rear right behind the wheel wells (common H2 problem)
No known mechanical issues
Normal wear and tear interior and exterior
Yellow 04' H2
