Old 09-01-2015, 02:47 AM
Dogpoor Dogpoor is offline
Dogpoor is on a distinguished road
Default Radiator leaking trans fluid
Noticed a small spot of fluid underneath the H2 today. Investigated and can see transmission fluid seeping from the upper radiator on the drivers side. Fairly close to the upper transmission line. The transmission line fitting is tight, radiator seem must be giving way?
The H2 is a 2004 with a tru-cool transmission cooler already installed.
No evidence of fluid contamination.
Can I bypass the radiator trans cooler?
If so how?
Should I replace the radiator?
Any sage advice would be greatly appreciated.
Thanks in advance
