Old 12-29-2015, 07:01 AM
clsimmon clsimmon is offline
clsimmon is on a distinguished road
Default Highbeam Indicator
Has anyone come across a highbeam indicator dimly lit? It appears like there's a short somewhere, because it flickers sometimes, and then just remains faintly on. It just started doing this. My guess is that it's a problem in the cluster, but thought I would check here first if anyone has come across this
Old 01-10-2016, 06:41 AM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Default Re: Highbeam Indicator
Sounds like your gauge cluster is ready for the rebuild. I just had to get mine done. I went through circuit board medics and had all the stepper motors replaced/upgraded to the swiss switec ones, upgraded to LED, and they also updated some other known problem areas. There are many other rebuild outfits found by searching online or through eBay.
Old 01-15-2016, 12:00 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Check the ground at the very front of the left side frame rail. Make sure its tight and clean. Ive seen this ground cause all sorts of weird issues.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 01-15-2016, 12:29 AM
Humtech, where. exactly is that? I just checked under the hood. The only ground I can see to the chassis, is the braided ground to the firewall, to the left of the power break reservoir.
Old 01-16-2016, 12:03 AM
HUMTECH's Avatar
Its real close to your left front towhook.
1998 Chev Z71
Old 01-16-2016, 12:04 AM
HUMTECH's Avatar
Look through the opening where the towhook is from the front of truck and you will see it
1998 Chev Z71
Old 04-06-2016, 07:41 PM
Contract_Pilot Contract_Pilot is offline
Contract_Pilot is on a distinguished road
Having similar issue... I did the steppers a couple years ago.
