Old 01-15-2016, 09:51 PM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Default Just had to do the infamous blend door replacement
Unfortunately I had to replace the passenger side blend door actuator which is the harder one to get to at the top of the dash. I pretty much followed the instructions here on this forum and others and it was pretty much spot on. It cost a whole $34 for it. I guess our rigs are starting to show their age!
Old 06-07-2016, 10:54 PM
Lucky1 Lucky1 is offline
Lucky1 is off the scale
Default Re: Just had to do the infamous blend door replacement
What tool did you use to remove the 2 bolts on the blend door actuator ? I can't seem to get the bolt closest to the driver's side out with the 8 mm box end wrench I'm using. It's apparently too long or I don't know the truck. Thanks in advance.
Pimpin 8 E Z but somebodys gotta do it .
Old 06-11-2016, 07:11 PM
8mm box wrench. Maybe your's is too long? Mine has a slight angle also. I remember having to have one hand in through where the passenger airbag switch is and the other through the top and could only make small 1/8 of turns or less. Make sure you have it installed before you plug it in too.
Old 06-23-2016, 08:31 PM
Thanks Glenn. I think my box end wrench was too long so I just brute forced it. Lol.. I got it out and in with a sacrificial crack in my air duct tube. A little bit of aluminum tape and all is well. p
Old 07-10-2016, 03:53 AM
fllaw1 fllaw1 is offline
fllaw1 is on a distinguished road
Any photos taken apart?
Old 08-08-2016, 01:06 AM
I didn't even think to take pics. There are a few videos on you tube that might help if you are trying to get a visual. Just search H2 blend door.
Old 05-05-2017, 09:54 PM
Nielsen Nielsen is offline
Nielsen is an unknown quantity at this point
Glenn,... Can you verify for me that your passenger blend door had three fasteners or two,... also the price of $34.00 is good,... I'm seeing prices in the hundreds for the passenger blend door ???? Nielsen
Old 10-05-2017, 08:23 PM
I need to do the recirculated actuator. Too lazy/busy now.
Old 03-08-2018, 04:11 AM
I'm sure you already got it by now but for anyone reading it's three fasteners. My $34 one is still working fine. It's only an actuator.. not much to it.
