Old 12-12-2016, 09:16 PM
Wink Used Hypertech Power Commander III # 30022 2004-2006 Hummer H2
Hypertech Power Programmer III $135 shipped
2004-2006 Year Hummer H2
Part # 30022
Up for sale is a Hypertech Power Programmer III for a 2004 thru 2006 Hummer H2 with a 6.0 liter Gasoline engine. Hypertech's Power Programmers are some of the best bang you can get for your buck. You'll increase your horsepower and improve performance! This programmer is like new and is ready to use!
The part number is 30022.
Programmer is VIN unlocked and ready to be installed on another vehicle
Hypertech Power Tuning Features
Tunes the engine for maximum power and performance, plus potential gas mileage improvements
Three-Stage Power Tuning
Special Three-Stage Tuning for Select Vehicles
Dual Fuel Tuning
Lets you choose optimized tuning for 87 octane or 93 octane fuel
Engine Rev Limiter
Extends the engine's RPM range for a wider power band
Cooling Fan On/Off Temperatures
Permits use of low-temperature thermostat for cooler, denser intake charge and lower engine operating temperature
Transmission Shift Points
Optimizes shift points by speed and RPM for maximum acceleration
Transmission Shift Firmness
Firmer full-throttle gear changes for faster acceleration
Top-Speed Limiter
Allows the vehicle's top speed to be matched to the speed rating of factory-approved high-performance tires
Speedometer/Odometer Correction
Automatically corrects speedometer and odometer readings for non-stock tire sizes and/or non-stock rear-end gear ratios (accurate odometer readings are required by law)
Read and Clear DTC's
You Will Get The Programmer, Connection Cable, Installation Manual, and Original Box.
Free Shipping with tracking via USPS Priority Mail, Fed Ex, Or UPS.
(My choice based on lowest rate)
payment via paypal or postal money order
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
True Flow Foam Air Filter
